Hey!!! Has any one installed an Electric Supercharger (from www.force-flow.com) on a VL? As I'm wondering if it is worth it for the extra performance. I've not to put in a Cold Air Intake now and I do not intend to bore a hole in me car. Or has one out there installed one on their commodore or heard any reports about them.
Thanks.
All I've heard is that they are not worth buying. Who knows, I'm not sure if anyone off here has actually bought one to see how well it goes..
someone said they were going to do it a while back but there was never a follow up on it. i haven't actually seen one fitted so who knows. gonna look at the site for more info and get back to ya. i'm a 3rd year mechanical engineering student so i'll see how the design is etc
well they are claiming about 2psi boost with a turbine speed of 27500rpm achieved in 0.2 sec. however the turbine is connected to the tps and will only start when you have wide open throttle (WOT). you would be looking at a small gain of about 10hp. if you then got a chip to take advantage of the extra air you could be getting 130kw out of your RB30 for about $600. not bad but i really don't like it only working when WOT cos how often do you floor it, i know i usually only use about 1/2 and then full when i want to give it a bit. depends how you drive and what you want i spose. i would probably rather a chip or cam
if you have the money it could be a bit of fun, just to be different. lots of people will probably laugh at you if you tell them you have one, they seem to have a bit of negativity surrounding them. at the end of the day its up to you and what you want.
it has been coverd before this and Don Sutton a JC member explaned it really well that the effects of a engine would simply make the electric supercharger inaffective and really not worth the money
post number 8 is the detailed explentation by Don Sutton
electric superchargers
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
yeah its a load of rubbish
from the site
the more amps you are pulling the harder the alternator is working, pullign more power from the motor, it probably does boots power but you could spend $349 better than that.operating voltage of 11.5 volts, where the motor draws 46 amps
my web sitestuff on the XF throttle body conversion, calais interior and lots of other junk!
Thanks guys. The money would be better spent on a 2.5 inch cat back exhaust instead.
shit i didn't see that, thats a lot of current. just noticed the twin systems too, double the boost but double the amps too...not good
you would be best fabricating a bracket and a pulley, that allows you run a fan of the motors power.
that would need a bloody long belt tho, and be very hard to make up but i'm sure you would see good results with some gearing to make it spin at some ridiculous rpm like 70k
