Results 1 to 8 of 8
Thread: Performance Mods for LPG
    HSV VP Senator
    May 2006
    3rd planet from the Sun...
    Default Performance Mods for LPG
    Hey all, I have a VL Commdore 5 speed manual.
    Just wondering what performance mods can be done to a car that runs mainly on gas........
    Yes it is dual fuel, but I only start it and let it run for at least 5 minutes on fuel in the morning then switch it to gas.......
    Thanx for any info.........cheers
    Lets work as a TEAM and do it MY WAY!!
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    well if you want to spend big bucks, LPG has a very high octane so that means you could run a high compression without causing damage like is would on petrol but that means you couldn't run it on petrol, ever.
    also, if you want to run it on only gas, remove that cat converter as LPG doesnt have emissions that are compatible with the catalytic converter.
    run a cold air induction system
    probably sounds silly but if you dont run the car for very long on fuel just have 1/4 of the fuel tank full as its quite heave and will slow you down.
    other that the usual, cam, exhaust, porting, bigger t/body, etc etc i am not sure what mainly benifits a motor runnign on lpg
    my web site
    stuff on the XF throttle body conversion, calais interior and lots of other junk!
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Quote Originally Posted by VQXTC View Post
    Cant think 4 a VL but must have ur spark plugs 1-2 grades colder than standard..
    If u have NGK spark plugs that would be BCPR5ES-11.. The 11 on the end is the gap 1.1mm.
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    Jun 2005
    South OZ Adelaide
    Quote Originally Posted by mag View Post
    Also real good spark plug leads and a better coil if u can get 1.
    LPG is harder to ignite than petrol..
    J_D
    J_D is offline
    VN S1 and VS V8 Statesman
    Jul 2006
    Ipswich. QLD
    Be good to do a turbo setup with a boost controller. Wind up the wik on LPG and down on petty.
    Im not a complete idiot, some parts are still on backorder!
    Sep 2005
    vic
    yes that comment on the spark plugs by mag was a good one.
    try and get your hands on an aftermarked coil. Don't get those stupid spark plugs with the 4 tangs on the end, they dont create 4 sparks as some people think they do.
    what the pros do is aim the spark plug, so that the back of the tang is facing the right hand side of the block and the open side is facing the majority of area in the head.
    not sure if that makes sense...
    my web site
    Jun 2005
    South OZ Adelaide
    Quote Originally Posted by Stewart1000 View Post
    Yeh that spark plug aiming is called spark plug indexing, ok if you've got some serious horse power..
    Sep 2005
    vic
    yeah, not for the average person ay.
    i have been thinking about the LPG performance situation...
    you want to advance the timing, get the camshaft re-ground, you want as little overlap as possible, no overlap would be the best, not much lift, you want those valves shut as much as possible as you want alot of compression to make use of the octane, high voltage output coil. i dont know what sort of LPG system you are using, electronic injection, flow fed injection, vapor whatever. but if its not injection, think about upgrading to that if you want to have a powerfull car on gas
    my web site
  1. VX 6 Performance Mods
    By grimavxs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-11-2006, 12:18 AM
  2. Help with performance
    By VUkeS in forum V6 Development And Modification
    Last Post: 27-07-2006, 03:06 PM
  3. VL performance mods. what would you do?
    By Jason1987 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-07-2005, 02:01 PM
  4. VX SS Performance mods
    By Gerry Murphy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-12-2004, 09:20 PM
  5. vs performance
    By nvs78 in forum Car Audio
    Last Post: 17-06-2004, 03:13 PM
