Results 1 to 9 of 9
Thread: 2.0 or 3.0 nissan motors
    VR 5.0 SS
    Jul 2005
    new zealand
    Exclamation 2.0 or 3.0 nissan motors
    Hi i have been given two vl commodores with the nissan six motor but im not sure as to how to i tell if they are the 3.0lt or 2.0lt as they look the same. i dont think the vin plates are there as car has been used on a farm for a few years so no need for vin plates.is there another way to find out by looking at the motor itself or is there a plate somewhere else on the car. thanks for the help.
    vy_storm's Avatar
    vy_storm is offline just another moderator...
    VE Calais V 6L
    May 2005
    the burbs of Adelaide
    Thread moved.
    The how to section is for pre-written instructions, not requests.
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    as far as i know, the vl's only came out with the 3.0L, so unless theyve been swapped in, they should both be 3L
    SUSPECT's Avatar
    SUSPECT is offline Banned
    SUZUKI GSX-R 1000 k8
    Aug 2005
    adelaide, southern suburbs
    VL Wagon
    Jul 2006
    Hamilton, New Zealand
    yeah nz had the rb20, i think the diff ratios were different, im not sure on this but if its still the factory ratio the rb20 should be 4.11, and the rb30s got threes. again, just speculating
    Boredoms not a burden anyone should bear...
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    there were only rb20 in new zealand no rb30 na, i beleve there was 3 from memery rb30et that were imported at time of production for special people,
    the diff ratio for the rb20 would most likely be 4:11 and if its a rb30 motor 3:45,
    just had a quick check on my motor and spot 67S on the side of my block that could mean something, so ill see if it dose
    the plates are on the fire wall at the top right hand side if they are there these are the engine code
    LB9 Engine - V8, 4.9 Litre PFI
    LC6 Engine - L6, 2.0 Litre PFI
    LFI Engine - L6, 3.0 Litre EFI
    LV2 Engine - V8, 4.9 Litre High Compression
    LW5 Engine - L6, 3.0 Litre EFI Turbocharged
    Model: VL8VK19-125 (For instance)
    Body No:
    Trim: XXXX-25I
    Paint: 1J052-D
    Built:
    Eng: LC6 Trans: MX7 Axle: GM3
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    VR 5.0 SS
    Jul 2005
    new zealand
    to vy-storm what!! are you the police or something, ok "how" to tell the diffence between the two motors !! is that ok sir.
    SUSPECT's Avatar
    Aug 2005
    hahaha!!! lol thats gold adam, dinodog he's just doing his job and its such a hard job at that lol
    vy_storm's Avatar
    VE Calais V 6L
    May 2005
    Quote Originally Posted by dinodog View Post
    Sorry mate, not the police just doing what was meant to be done.
    I assumed you didn't read this post in the how to section?
    Prior to Posting in This Section
    All posts in that section are moderated and do not show up straight away. If this post ends up being a clearly written instruction, then by all means it may be moved over there.
    Sorry if it upset you in any way.
  1. Ford and Nissan
    By S Pack in forum Jokes/Humour
    Last Post: 12-10-2006, 08:13 PM
  2. Gas Turbine Nissan Vid
    By Lexx in forum General
    Last Post: 17-08-2005, 08:08 PM
  3. 1989 Nissan exa
    By patrix in forum General
    Last Post: 09-07-2005, 09:59 PM
  4. nissan 720 ute
    By shane0o7 in forum Parts And Other Items For Sale
    Last Post: 12-09-2004, 10:33 PM
  5. Nissan Skyeline
    By Garth in forum General
    Last Post: 15-04-2004, 10:29 AM
