Hey all, I have a really weird problem with my vent controls.......when I sit stationary all works well.......but when I take off and the rpm reaches just over 2,500 then the vent changes direction from face to floor ..... but when i change gears it then goes back to the face and so on and so on......
Any ideas..... cheers???
Lets work as a TEAM and do it MY WAY!!
Ohhh dear....thats weird all right. I'm guessing a wire is wrong somewhere. Or loose connection and the little jerk you get when you change gears is making something move. There the only things I can think of.....
:: hakhawk :: says:
im a geek by day
:: hakhawk :: says:
a mass/axe murderer by night
:: hakhawk :: says:
and a rabbit sometimesI'm only nice to one person per day. Today is not your day....
Tomorrow doesn't look good either.
God must love stupid people, He made so many.
theres a complicated vacuum system for the heating and air cond, using rubber tubes and a vacuum tank under the front bumper, maybe something is wrong with it
its easy to accidentally pull these hoses off when probing under the dash
dead on. it'll be vacum related, considering your vents are almost solely controlled by the vacum created by your runing motor. check for sucking noises.
if in doubt, have a mate look around the engine bay and at the vacum ball under your bumper on the driver's side while you bring the rev's up and down.
good luck.
