Results 1 to 5 of 5
Thread: VL Diff and Brakes Help.
    VL
    Jul 2005
    SA, Mount Gambier
    Default VL Diff and Brakes Help.
    Hey all, i was putting in my minispool today and while taking out the axel shaft i noticed my brakes are stuffed, and then i didnt make them any better by bashing them and using them as leverage to pull out the shafts. Anyway, i thought i would look into replaceing the factory drums with discs. What will i need to fit discs onto my vl? (rotors, calipers, caliper brackets etc etc) can someone please elaborate.
    btw i i have a 25spline with 3.45's - minispooled. Ive also started my vlt conversion today and interested to see how long it will take to fcuk up my diff and then my tranny which will soon have a cooler. However many people have told me that the na auto tranny can hold up and a cooler and properly maintained, but the diff ive heard mixed opioions, i might have to invest in a 28 spline but im no interested in upgrading the diff just yet.
    Lastly, has it always been hard to get the shims and bearing cups back into the diff?
    SUSPECT's Avatar
    SUSPECT is offline Banned
    SUZUKI GSX-R 1000 k8
    Aug 2005
    adelaide, southern suburbs
    yea invest in 28 spline axle's dude the 25's wont last very long with the spool, oh and the na tranny will hold up for a while but not really all that long
    VL
    Jul 2005
    SA, Mount Gambier
    Would the 28 splin axles fit in the 25 spline center with a 28 spline spool? or in other words, are the 28 spline shafts the same thickness?
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    not sure abput the shafts, i'b be calling up all the wreckers around your area tryign to see if they have any calais diff's or a calais you can go and pull it out yourself, i found one at my local wreckers the other day.
    i reckon if you get a good service done on the auto and run a big cooler it should be good.
    my web site
    stuff on the XF throttle body conversion, calais interior and lots of other junk!
    VL
    Jul 2005
    SA, Mount Gambier
    Why calais diffs? they should be the same as my SL unless it was turbo or 5.0L.
  1. V8 Diff vs 6cyl Diff
    By RSO in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2009, 09:45 PM
  2. diff making a noise / replacing diff
    By yipya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2008, 11:30 PM
  3. Putting in new diff oil and replacing diff gasket ?
    By gemini in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-10-2007, 05:22 PM
  4. lsd diff and disk brakes for my vk
    By 85_VK_EFI in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-11-2006, 10:45 AM
  5. VT Brakes
    By mikemutlow in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-09-2005, 09:56 PM
