Results 1 to 11 of 11
Thread: just bought rb30. now im cool
    Oct 2006
    Default just bought rb30. now im cool
    i have a vh commy, did buy 202 turbo. but nar fug it, i bought a rb30 2 day. was a turbo'd motor, now n/a. there in lies the problem, i need a t3/4, highflowed or not. turbo.. under $600.. help a brother out boys
    need my 202 power, PIMPVH
    vl berlina wagon 6cyl
    Jul 2005
    its not easy to put a nissan engine into a VH if thats what you are planning
    VH SL/X
    Apr 2006
    Brisbane, Queensland
    Quote Originally Posted by harry3 View Post
    Why is that? It's the same engine bay as a VL isn't it?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    More technical than physical I think. Wiring loom, ECU, Transmission and drive shaft I think too. The VH could also have a narrower engine bay.
    vs calais eco
    Sep 2006
    Disney land!
    dont forget that the vl had the fault of poor flow in the cooling system due to the radiator being to high! (factory engineering mistake not found in the r31) to compensat holden put a bafle inside the radiator but it can become dislodged with age! just something to think about
    VT SS S2 A4
    Aug 2005
    POVRTY's Avatar
    POVRTY is offline building 5L VB TH 400
    VE SSV 6SPD WGN
    Dec 2005
    taree nsw
    there is heeps of rb's in vh ect......just do some searching and some homework and you will find all you need to know
    VT SS S2 A4
    Aug 2005
    Quote Originally Posted by cxcxcxvcvcvc View Post
    The radiator is lower than the top of the head, that is where the trouble comes from, but if you bleed the system correctly you should have no worries at all.
    lc torana. vn v8. ke30.mazda 1300.
    Mar 2006
    i know ud be able to pick up a t3 for 400-500 off calaisturbo theres always turbos poppin up on there
    wrecking VL COMMODORE 5 speed
    FOR SALE : supra 5 speed box suite holden v8 $800
    It's quicker then your mothers VN
    Sep 2005
    At the time of this post, under your mothers bed with my laptop
    everything from a vl will bolt upto the vh so its all bolt in the old hard bit is wirering it all up
    Jan 2006
    Quote Originally Posted by rb26dett View Post
    Yep mine's never had any issues, with the head. (Only a leaking injector once)
  1. Nissan RB30 V Holden RB30???
    By neatvl86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-01-2011, 01:08 AM
  2. A cool kit for your car
    By craigvk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-11-2005, 03:01 AM
  3. best way to get cool air in
    By chevy_big_block_bro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-09-2005, 08:17 PM
  4. This Would B Cool
    By spice_man2069 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-10-2004, 09:37 PM
  5. Cool!!!
    By DavidPartay in forum The Pub
    Last Post: 21-08-2004, 10:35 PM
