when the car gets to a certain temp is the electric faan ment to come on?
my car cooling system has all been fixed but it seems the electric fan doesnt come on. And the heat and air con switch in the car u cant hear the fan when u turn in on.
any advice be great cheers
If you own a Vl, it should be running a clutch fan.
If you dont hear the fan for the aircon, you will need to see an auto elec.
The electric fan on the front of the radiator,i think is only for the a/c condensor and not for the temperature of the motor because this is done by the constant fan on the waterpump pully.
Soon to be back on the road, Turbo VG.
if the cooling system isnt working properly in summer, the air cond compressor will top after a few minutes as it senses high too pressure in the air cond system and this cuts off the compressor as a safety thing
the common cause is failure of the clutch on the main fan, the electrical fan cant make up for this failure, assuming it fails so the main fan just idles
