Results 1 to 17 of 17
Thread: BOV/exhaust
    VL Berlina 5speed turbo
    Apr 2006
    Default BOV/exhaust
    Hey Guys,
    I have a BOV un known of the brand and my birthday is coming up and my parents want to get me a new one, My one atm flutter's when i dont get into her, is there any bov that basicaaly flutters no stop?
    and i have a 3" but it's not as loud as every other vl i hear with a 3" on, is there a way to make it a bit more loud?
    thanks heaps
    VN Wagon,
    VT SS S2 A4
    Aug 2005
    May I suggest a GFB Stealth BOV.
    It has the ability to be changed from plumb back to venting to atmosphere just buy turning the top of it.
    Apr 2006
    OK that sounds alright,
    do they sound alright mate or just like any other bov?
    cheers
    VN Wagon,
    VT SS S2 A4
    Aug 2005
    They can be loud, but not overly loud.
    It depends on what you want.
    If you want pure noise, probably one with the twin trumpets would be the go.
    Apr 2006
    Yeh i want pure noise, i was looking at the turbo smart one, the 3 way one, you can make it plumb back,moderate,or really noisy
    doesn't look to bad but it's arounbd $450
    VN Wagon,
    VN v6 s2 Berlina 5spd
    Mar 2006
    hi.
    im sort of into vl's but don't know heapz bout them.
    is the fluttering sound you want even from the show off valve?
    or is it from a dose pipe?
    or does the does pipe just magnify it?
    VT SS S2 A4
    Aug 2005
    Apr 2006
    NAh not a dose pipe,
    Mine flutter's when i dont get up it, but was wondering if one did it all the time, i dont want a dose pipe
    VN Wagon,
    VL
    Jul 2005
    SA, Mount Gambier
    So u want a BOV that flutters? i would be cheaper to get a dose pipe, and then u can change the pitch, loudness etc etc. btw u need a cooler to dose it.
    Mar 2006
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    From my limited knowledge on the whole dose bullsh*t I gather that no bov causes the fluttering, which isn't always a high pitched noise, it all depends on what you have connected to your inlet of your turbo.
    No way to relieve excess pressure from the t/b back so it gets vented back out of the turbo's inlet, through the blades and if you have a dose pipe, through the pipe, if not its back out into the airbox or through the pod. Which would break up the sound.
    However, with a bov once you've reached the limit that your bov is set too you get your high pitched trumpet or pssht noise, depending on the bov.
    Reading the first post I'm under the impression that your bov is set to relieve pressure after so many psi, which is why its only really making noise when your getting under it, all other times I believe the noise you are hearing is just excess pressure coming back out through the inlet of the turbo.
    Chris
    VL
    Jul 2005
    SA, Mount Gambier
    is a bov still used to dose?
    cheers
    NO
    And you can NOT "dose it" when u have a BOV.
    Chris
    U can get special bov's that do differnt sounds etc.
    A bov isnt forced open by the boost in the crossover pipe, it is sucked open by the vacume on the other side of the throttle body (in the plenum), thats what the hose on the little on top of BOV is for.
    A valve that opens under pressure (forced open by boost) is called a bleed valve. DO NOT CONFUSE THE TWO.
    The tone of the dose is changed by the lengh, width and degree of bend in the pipe.
    VL
    Jul 2005
    SA, Mount Gambier
    Getting a studdering sound out of a bov would be possible depending on the spring and the amount of vacum ur motor makes.
    Heres my idea of getting a BOV to flutter, Example... say your car makes 10psi of vacum in 5 secs, and your bov is set to go off at 8psi, once the plenum is back to 8psi the bov will close, and the motor will make more vacum instantly thus rasing vac to 10 again and forcing the bov open.
    dont quote me, correct me if im wrong.
    Vl Calais
    Oct 2008
    Hey Guys,
    Here is a step by step guide on how to Dose.
    HOW TO MAKE YOUR VL DOSE (Step by step) - calaisturbo.com.au
    you need a Pod Filter and an intercooler, that's basically it
    Hope it helps.
  15. #15
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Quote Originally Posted by adamb08 View Post
    Hey Guys,
    Hope it helps.
    Haha gota love that site if ur a vl owner
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
  16. #16
    86 VLCT/ 03 II VY SS Ute
    Aug 2007
    i kno what this guy is trying to say my mate has the same sort of bov on his silvia its not a dose it just makes a sort of dose sound when changing at low revs and then when giving it shit it does the classic bov sound, as for one that does the dose sort of sound all the time im unsure mate, and also if you like the sound of the bov's that do that you would love a dose pipe lol dose it more high pitched rather than the low pitch bov, hope that helps some how lol
  17. #17
    Goon's Avatar
    Feb 2006
    GC. QLD
    Get ur hands on an adjustable turbosmart blowoff valve, i got myself one, type 2
  1. List Of Exhaust Quotes no it's not another exhaust question:)
    By Thomas1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-11-2006, 08:57 AM
  2. Specify what I want in my exhaust
    By ciaranvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-11-2006, 04:03 PM
  3. HSV exhaust
    By Philthy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-11-2006, 07:34 PM
  4. VT Exhaust (not jst another exhaust thread)
    By raZel in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-09-2006, 03:50 PM
