Results 1 to 9 of 9
Thread: vt thermo fans in a vl auto
    VL exec wagon
    Oct 2006
    Default vt thermo fans in a vl auto
    i'm looking at buying a thermo fan setup from a vt and i was wondering if anyone had any info on the install procedure? it's going into a vl auto and i've read that the trans cooling lines might pose a slight problem. also what other parts do i need? ie thermostat to tell the fans to turn on, or extra wiring or relays etc. any help would be appreciated
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    you'll need a thermo switch to tell the fans when to come on. i think the switch out of a sigma may be compatible. you will probably need to make up the brackets or modify the vt one.
    VL exec wagon
    Oct 2006
    cheers. whereabouts does the switch end up getting fitted to the engine? does it receive a signal from the ecu or is it an analogue switch (thermostat type)? is it worth going doing the conversion? when i use my a/c in summer my temp gauge goes up to half, i've been told that's normal for a vl, but will this conversion help much?
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    its not going to make that much difference. you'll get a little bit more power by removing the viscous fan. the switch looks like a temp sender.
    executive vt 5.0lt
    Feb 2005
    west suburbs
    why not put in a bigger radiator,? thats what i did ,and the temp gauge hardly
    moves summer or winter
    VL exec wagon
    Oct 2006
    VT SS S2 A4
    Aug 2005
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    If you want to make life easier on yourself steer clear of the VT's. Grab a set of EF/EL Falcon twin thermos which will fit in like they were made for it. As for switching them on if you want to do it simply head down to SuperCheap and grab one of the Davies Craig thermatic switches. These run in the radiator hose and you just turn the dial to the temp you want them to come on at.
    AirStrike
    Selling FG G6E Turbo and buying a N/A Supra
    VL exec wagon
    Oct 2006
    thanks man! thats what i'll do.
  1. Thermo fans into a VC
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-06-2009, 02:46 PM
  2. Thermo fans
    By 12000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-05-2007, 03:19 PM
  3. thermo fans
    Last Post: 16-04-2007, 09:37 PM
  4. Thermo Fans
    By bigg_vin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-09-2006, 12:14 PM
  5. thermo fans
    By urmyho in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-07-2006, 10:44 AM
