Results 1 to 7 of 7
Thread: Clutch Fan Coupling
    VL SL
    May 2006
    Default Clutch Fan Coupling
    Any Ideas on how much a replacement Clutch Fan Coupling would set you back as new from one of the major part stores, or a second hand from a wreckers?
    Wondered what the noise was comming from under the hood, sounded like someone put some dice inside the rocker cover and it was rolling around, was the vibartion from the Clutch Fan Coupling going through the whole motor
    Any ideas on price?
    VL
    Jul 2006
    good excuse to get thermos
    the clutches are around $100 or so new i think for a dayco or repco one
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    about $160. i just sold one to a guy the other day. part number is 5001 for 1 brand, not dayco.
    Holdfast is offline Donating Member
    VE & VL
    Jan 2005
    vl berlina wagon 6cyl
    Jul 2005
    shop around theres a big range, I wouldnt bother with used ones
    be sure to ask for all discounts
    it helps to have small fingers for the bolts which are fiddly, ellerys manual says toi locktite the bolts
    when failing, they sometimes leak silicone but not always
    VL SL
    May 2006
    Managed to pick up whole unit, the coupling and fan for $100 from Burons, now comees the fun part of pulling the other one off and putting this one on, its got an extra blade, i figure will work less, with one more blade distributing the work a little more.
    What do you do if you dont have small fingers,cause im totally ****ed if thats the case
    VL SL
    May 2006
    What a prick of a job, had a bit of a hard time, you really do need small hands, only prob is it still making this dice, vibration noise from around the same area, theres no give in the fan anymore so thats good, but im wondering if this woudl have affected the water pump?
    Any ideas on what else could be causing this most annoying noise, its never been there ever before?
  1. Thompson Coupling
    By Clinster in forum The Pub
    Last Post: 24-02-2007, 12:01 PM
  2. Clutch
    By feistl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-07-2005, 02:23 PM
  3. VN SS Clutch
    By dpac in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2005, 06:52 PM
  4. Rubber Coupling
    By VZLAD in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-06-2005, 08:08 PM
  5. Viscous Coupling -> Electric Fan
    By jetspin_vn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-01-2004, 10:52 PM
