On the weekend i went to a show and gave my car a bit of go on the grass,
For some reason it was reving arounnd 6 when i jumped on the break;s it cut out did it a few times,
and the blow of valve had a bit of oil(looked like it anways) come out wasnt much just wondering what it was?
and how do you check if the injector's are leaking?
thanks
VN Wagon,
could be detonation or even back firing...Have you got a burst plate installed?
Oil out the BOV sounds like blowby
what is blow by?
and what is
"Have you got a burst plate installed?"
thanks
VN Wagon,
Blowby is fairly common on a turbo.
It is oil getting past the rings.
Is that something to worry about or is it ok?
it's going in for it's first dyno tune since i have owened it not this friday the following so might see what they have to say.
VN Wagon,
i wouldnt pull my hair out about it but do try and get it fixed sooner than later
