Results 1 to 6 of 6
Thread: Rear head rest
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Default Rear head rest
    something ive been wanting to do for a while now is get some rear head rest set up in my car.
    so i was wondering would front head rest work? or dont they pull out at all?
    i possibly can get my hands on some front head rest too,
    my rear seat is good and i am wanting to keep it, so is there anyway to get the head rest legs though the trim with out needing to retrim the whole seat?
    would just cutting though work?
    and finally the brakets for the legs, anyone got any pictures on them as i make a pair of them up
    cheers
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Oct 2005
    well ive answerd one of my questions my self
    front head rest do come out, just need a screw driver or needle nose pliers and run them down the headrest legs till you find the circlip holding them in,
    so ll i need is a side on view of the brakets, found some front on pics but need side on so anyone please help with this....
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    i wanna do the same thing to my wagon should look sweet as... free bump
    Going where no late model stato/caprice has gone before.... GAME ON!!
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    I'll post some up when I get home tonight. If your doing it with your own seats I reckon its possible that you could make them yourself.
    Your using SL seats? Or berlina, something without head rests in other words?
    Your going to have to cut the hole in the center, and then trim out a fair bit of foam from behind where they go. Best bet is to line it up without the seat in there and have a look at where you'd want them to sit.
    For the brackets we had a rough idea going by probably the same picture your looking at, then we just crafted up a few bends so they kind of looked like an D, then we welded that to the back panel. At the moment it isn't going to work properly as I have the wrong clips, but I'm guessing it could be held in with hose or anything, zip ties.
    Go hard son
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    The seats already have the foam cutout for the brackets to sit.
    You just need to cut the holes for the head rests to go into the seat.
    You can fabricate up brackets or buy secondhand ones you will need the retaining inserts as well ([shameless plug] which im selling a set of)
    There is a howto on the brock commodores forum on fitting the brackets, you should weld the brackets, if not use the Stork metal bonding glue its Australian Standards approved and will glue the brackets on well.
    Else weld a piece of steel tot he back of the bracket & bolt them to your car.
    cheers
    Scott
    Oct 2005
    cheers for the info, looks like ive found my self a new job to do
    yes they are berlina rear seats so the holes are not in the trim so i will just cut some in.
    here are the pictures i stumbled across to give u a idea what ive got to play with
    Attached Thumbnails Attached Thumbnails Rear head rest-vl-head-rest2.jpg   Rear head rest-vl-head-rest.jpg   Rear head rest-vl-head-rest3.jpg
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  1. Rear centre arm rest stuck
    By calaiswa in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-11-2007, 01:54 PM
  2. Head Rest Holders for VS caprice back seats
    By pugga in forum Swap / Wanted to Buy / Trade
    Last Post: 23-01-2007, 10:34 PM
  3. Head Rest Removal?? How??
    By VHSLX3300 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-01-2007, 01:12 AM
  4. Rear head rests
    By awhite_au in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-12-2006, 10:02 PM
  5. Head Rest inserts Real or fake
    By Pub247 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-07-2006, 06:34 PM
