I got defected on monday,
and i have to take of my boost controller and blow of valve and pod.
If i take the bov of what can i use to cover the whole in the intercooler pipping where it sit's? and if im going to put a plumb back on it could i fouled the house over the run's to the bov and cable tie it up untill i get a plumb back?
and the boost controller i know nothing about these, but look's like a house run's to the turbo aswell? how do i take that of? if i want to hide it later could i just cable tie that up aswell or?
and then how do i adjust my boost with no controller?
and one more does any one have the intercooler pipping run under where the air box nearly is? if so how do i put a orignal one back on it? or do i have to modifie it a bit to fit?
thanks
VN Wagon,
Sounds like they got you pretty good.
Not sure what your talking about with the bov, if you sell your current one and put a plumback straight on you shouldn't have troubles with covering the hole. Until then you'll need to clamp something over it, something strong that won't give.
The boost controller is just the hose coming off your actuator, it should have a t piece in it that runs to your boost controller, If you take the t-piece out and re-join the line from the turbo outlet to the actuator itself, you should have standard boost (from my knowledge) someone confirm please.
Intercooler piping under where the airbox is, yep. How do you put original back on it? The airbox? You'll need to either get a pipe made by an exhaust place that comes off your turbo inlet, back over to where the original airbox sits, either that or you can go to a wrecker and get the metal pipe, the rubber pipe, the flexihose and the airbox.
Hope that helps a bit.
