Results 1 to 23 of 23
Thread: It all started with a broken timing belt
    VL Wagon
    Dec 2006
    Default It all started with a broken timing belt
    Hi Peoples I'm after a bit of advise...I did a timing belt on my VL I think I found top dead centre( both valves closed, piston at top of stroke, rotor pointing to no. 1, 1st mark from the left on harmonic lined up with mark on timing cover) replaced the belt retensioned according to the Haynes manual turned it over had what sounded like huge exhaust leak and not enough power to move the car, took head off, reseated valves, replaced 5 broken exhaust studs put it all back together and won't go. Did computer diagnosis all came back clear except speed sensor cause I can't move the car, can only get orange-red spark from grounded coil lead and spark plug when the manual says it should be blue. Any ideas would be appreciated
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    if you broke the belt while the car was running you valves will be bent... time for a new set
    Going where no late model stato/caprice has gone before.... GAME ON!!
    Sabby's Avatar
    Sabby is offline MSABBY
    VU SS FIFTY
    Sep 2006
    melbs
    BIT_SUS's Avatar
    BIT_SUS is offline only dogs chase cars
    TTvk,gts kitted VL
    Nov 2006
    house hope so!!
    broken valves haha if ya lucky maybe a couple of bent conrods aswell.
    id say get a second hand engine or rebuild it cheif..
    BIT_SUS's Avatar
    TTvk,gts kitted VL
    Nov 2006
    house hope so!!
    HZ Sandman Ute, HZ GTS, VT Senator
    Apr 2006
    PM me if ya interested in a near new head (only 20,000km) or if you want a good s/h one thats done about 200,000. or even if you just want valves i have a head that is cracked that i can pull apart for bits u may need.
    cheers
    jason
    VL Wagon
    Dec 2006
    Timing belt broke as the car was started no bent valves, they were checked, no marks on piston tops or anything indicating any strike damage between valves and piston top, will do a compression test today see what comes up.
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    borrow a friends coil and do a quick swap and see if that changes the spark colour.
    VL Wagon
    Dec 2006
    I replaced the coil yesterday and no difference, I tested the power transistor and it isn't that either, the crank angle sensor has been replaced a few times over the years but that always shows up on the computer diagnosis test and it didn't come up this time. I've got a spare CAS but doesn't sound like the CAS has gone.
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    CAS doesn't have to show up on the sensor to be on its way out, but your right it doesn't really sound like a CAS.
    I don't see how bent valves would cause orange red spark from the coil.
    Battery fully charged? Does it take long to turn over?
    VL Wagon
    Dec 2006
    Yeah reset ECU and battery fully charged, will crank instantly and strongly just no sign of firing.
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
  15. #15
    VT SS S2 A4
    Aug 2005
  16. #16
    VL Wagon
    Dec 2006
    Will try a new coil lead and do a compression test today see if anything comes of it
  17. #17
    genetic_freak's Avatar
    genetic_freak is offline Technical Geek
    VR berlina 304
    Nov 2006
    the rb30 is a free spinning motor. so logically speaking you wont bend valves.
    if you have a orange red spark then the most likely cause would be low voltage in the spark system, ie coil, cap rotor etc. or it could be you have missed an earth somewhere.
    hope this helps
    Its a common miss conception that people actually use their brains before they speak.
  18. #18
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Arrow
    Quote Originally Posted by Simion View Post
    Any news yet??
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
  19. #19
    VL Wagon
    Dec 2006
    Haven't been able to get to it today...will try and get to it on sunday, will be a pity if it is dead the engine was so clean when it was opened up
  20. #20
    vz wagon
    Aug 2006
    Wild west of Melb
    Could the belt be 1 tooth out ? hence the weak spark ? I wouldent kno never had any thing to do with a vl just an idea that came to me wile reading this thread.
  21. #21
    vl berlina wagon 6cyl
    Jul 2005
    are you saying the RB30 is freewheeling and not interference when the belt breakes
    I thought it was interference with bent valves, pistons and maybe rods
  22. #22
    VL Wagon
    Dec 2006
    Couldn't tighten the compression tester into the spark plug holes so only read 90 psi per cylinder for all 6 pots and the coil lead was replaced and still nothing...anybody want to buy a VL wagon with a motor that should be going ??....Thanks to all that replied to this thread
  23. #23
    Jun 2005
    South OZ Adelaide
    Thumbs down
    It was running fine b4 the belt broke yes??
    If so ur going to have to take it apart again and re-check the timing marks for the cam belt, it MUST be out!!!
  1. vl timing belt?
    By starfire vc in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-06-2010, 09:06 AM
  2. HSV double-row timing chain vs timing gears
    By savage1987 in forum V8 Development and Modification
    Last Post: 05-10-2007, 12:04 AM
  3. Whats the price on a timing belt..
    By Goon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-09-2007, 09:17 AM
  4. when i started my car
    By badger__rox in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2007, 12:28 PM
  5. New Timing Belt Installation
    By Dan355 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-11-2006, 12:11 PM
