Results 1 to 7 of 7
Thread: Overdrive Clutch Shudder
    Nov 2006
    Default Overdrive Clutch Shudder
    Hi all,
    Have just got an automatic VL on the road for my daughter, but after driving round this afternoon for the first time have noticed when it drops into lock up mode under any load the clutch shudders very badly until you back off then it locks into place and all is good. If it changes when under no load, ie nice flat road and gentle acceleration, it is fine.
    Is this the start of the end? Was thinking of just disconnecting the clutch solenoid to disable the lockup but keep overdrive - any opinions? Bearing in mind it is her first car and in no disrespect to her or her driving, I honestly dont expect the rest of the car to last too long....
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    the clutch lock up is overdrive and it's ok to disconnect it you'll still have 4 gears and she won't notice anything.
    Nobody wants to play with me
    VT SS S2 A4
    Aug 2005
    Nov 2006
    OK, so its not just a case of the box needing a service, it is telling me the clutch is gunna fail huh. I had a VL myself back in bout '90 and the clutch failed on that one (fell apart) and went through the box blocking the oil galleries and cooked it in the middle of a trip from Sydney to Canberra - hence my concern
    Think I will disconnect it on the weekend when I see her just to be safe
    VT SS S2 A4
    Aug 2005
    A good tip for jatcos is to run a trans cooler, that will help prolong the life of the gearbox.
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Quote Originally Posted by rb26dett View Post
    It's good to run a trans cooler on any auto..
    Drop 20degs and it doubles the life..
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    vl berlina wagon 6cyl
    Jul 2005
    also jack up the trsnsmission a bit to see if the rubber rear engine mounting rubbers have split
  1. vs auto not going to overdrive???
    By sganro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-06-2009, 11:53 AM
  2. in and out of overdrive
    By 2greedy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-03-2007, 11:41 AM
  3. What is your rev change from 3rd to overdrive
    By gibbo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-06-2005, 04:50 AM
  4. Overdrive
    By rave84 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-05-2005, 08:46 PM
  5. Webber Overdrive
    By VSTrev in forum Motorsport
    Last Post: 27-02-2005, 01:08 PM
