Hi, I'm fitting a VL ignition coil to an MG and I'm unsure of the polarity of each terminal. Anyone able to help me out?
If you hold the coil so the terminals are facing you and at the top, the left one is+ve and the right is -ve
Originally Posted by bezz_86 Hi, I'm fitting a VL ignition coil to an MG and I'm unsure of the polarity of each terminal. Anyone able to help me out? Be careful if you wire it backwards you'll suck you're sparkplugs up you're ignition leads.. Joke..
I was confused now I'm just not so sure!! RIP Peter (perfect) Brock....
Originally Posted by Tree cutter If you hold the coil so the terminals are facing you and at the top, the left one is+ve and the right is -ve Cheers for that buddy!
Forum Rules
