Today my engine blew![]()
but now i guess it's time for some projecting and get it bigger and better than ever.
BAX- with you remvoing yuour door lock's, did you just tack a metal plate behind it and bog over?
cheers
VN Wagon,
Spewing well at least you can look at the positive side... Good luck with you "Bigger and Better" plans. I hope it all works out.
how did it blow
what happened
Yeh I was a bit angry but in the end it's a car, might be a bit of money down the drain but once i finished i wont have to worry again,
Well i went to get new lifter's he said bit more serious than that, 3 mechanics said lifter's and pistons snapped and sounds like the rod going crazy, on the way to where it getting stored, started blowing flames from oil, then turbo fully went with nice white clouds then a nice loud heavy noise then oil puissing out of the engine, and the oil pressure gauge was going crazy.
So time get motor out sand her back new paint job and engine![]()
not in a rush to get it all done, if i go steady i will go proper but if i rush ahaha i stuff things up
VN Wagon,
dam thats a shame man are you gunna get another turbo engine or what?
Going where no late model stato/caprice has gone before.... GAME ON!!
