Originally Posted by
wagonb0y
It's started finally,
Starting on the rust sanding back over my chrissy break,
the motor still hunting around found a genuine turbo motor and i think that be the one i get,
im chasing 300hp
so plan's so far,
GT35/40 turbo
manifold top mount,
plenum
injectors
cam
forgie pistons
bosch 044 pump
anything else you guy;s think need doing,
i will be running 6psi normal and 15 when i wana give it a bit, i just really wana build a strong motor and if i crack 300hp i be very happy,
anything else you guy's recomend?
