Results 1 to 5 of 5
Thread: crank sensor
    vl
    Dec 2006
    Default crank sensor
    Need help, have done the wiring to the crank sensor, having trouble with the dizzy, cap off,etc. I need to remove the small timing wheel and shaft to remove the sensor unit. any help would be great. Thankyou::
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    TO remove the disc you need to undo the screw inside the shaft from the top.(there could be a rubber or felt plug in the top of the shaft that has to be removed so you can see the screw) Then you can lift off the top half of the shaft so the disc can be removed.Be careful with the disc so you dont bend or crack it. Next i think you have to use a hammer and punch to hit the little pin out of the drive gear on the bottom, then pull the gear off so the shaft will come out through the top of the housing. Now you should be able to undo the three screws that hold the CAS in and remove it.
    vl
    Dec 2006
    vl
    Dec 2006
    Quote Originally Posted by katana View Post
    tree cutter, thankyou, took a while but i got there.had a little more trouble, after 20 ks, turned it off, wouldnt start again.finally worked out the coil was faulty . ok when cold, when warmed up, I now have the car running great, also a reconditioned dizzy and a spare coil. thanks again
    Apr 2006
    Mt Gambier SA
    Good to hear you got her going. At least you shouldn't have any ignition problems for a while.
  1. Crank Angle Sensor
    By RockyC in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-12-2011, 09:02 PM
  2. Crank anlge sensor
    By Gillz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-10-2007, 07:09 PM
  3. why is this the 3rd crank sensor in 15,000????
    By IBLOWN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-07-2006, 08:48 PM
  4. crank angle sensor
    By timboco in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-05-2006, 05:35 PM
  5. Crank Angle Sensor
    By Stretcher Bearer in forum General
    Last Post: 22-11-2005, 03:22 PM
