Results 1 to 5 of 5
Thread: no low/high beam
    Feb 2004
    Question no low/high beam
    After driving for a good hour with my low beams I reached home let the vehicle rest for an hour. Was planning on going out for dinner, start the engine, flick the light stalk twice to get low beam....NOTHING. The park lights work correctly (1 flick) but the low beams don't. Can pull back and hold the stalk for high beam, if I let go I get nothing - no light.
    Checked the proper fuses all are fine. I've never liked the headlight stalks in the VL's, seem fragile. Could it be the faulty switch mechanism in the stalk requiring a new one? Like to hear anyones thoughts. Taking the car in for its pink slip Friday.
    Also anyone know where I can pick up a working wiper switch for a VL, rung round wreckers don't have em. Or wanna charge me $50 to get one in.
    VL executive
    Aug 2004
    its your indicator stalk for sure... had it happen twice now, and your right they are very fragile... i got one that broke 2 weeks after getting a new one... i got one for like 20 bucks or something from a mate through a mate through a mate and so on so dont know where exactly but ill find out... theyre easy as all hell to fit, so if you can get one just install it yourself...
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    I know its a long shot but check the actual headlights.. I doubt it but its worth a shot.
    I paid 50 for my indicator stalk.. And yep easy to install, take off the boss kit and steering wheel as one piece, undo a few screws and disconnect the loom, slide it out, push the new one back in connect it up, few more screws and steering wheel back on straight.
    As for the wiper switch, try a different wreckers? Should only be 10 bucks at the max for a second hand one and they should be in abundance..Try CWreck if you have no luck anywhere else.
    Number will be in the phone book.
    Aug 2004
    hey dude,
    You might be able to save yourself the hassel, replace the relay switch in the fuse box, had the same probs and thats all it ended up being
    mixin is offline Ol' fart, young heart!
    May 2004
    Country Vic
    Yep, that's my thoughts - the headlight power relay. There are 2 of them - a 4 pin one for power, and the 5 pin one to select lo/hi.
    It will be the 4 pin one for sure, and you can probably test it with one of the other 4 pin relays in the box to make sure.
    Don't go & buy a standard replacement - the bosch ones in the VL have a different pin out to the aftermarket ones, so you need to get a black plastic 4 pin bosch one - they are in all VH-VS commodores so just find a wreck to grab one from!
  1. High Beam on VK SL
    By booma11 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-10-2006, 01:19 PM
  2. high beam on and off
    By abehrendorff in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-02-2006, 06:05 PM
  3. High Beam lights glowing when on low beam ?
    By Madhouse_Dave in forum Electrical Wiring / Questions
    Last Post: 03-09-2005, 10:15 AM
  4. high beam....
    By stock_vl in forum Electrical Wiring / Questions
    Last Post: 12-05-2005, 11:03 PM
  5. VT High Beam
    By budge in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-03-2005, 04:39 PM
