+ Reply to Thread
Results 1 to 6 of 6
Thread: removing berlina/calais door strips/trims?
    phat_com's Avatar
    phat_com is offline VR IS A BEAST WITH NEW V6 phat_com Executive
    VR s2 Acclaim/VK IS GONE :(
    Jan 2006
    Tuggers (da hood),ACT
    Default removing berlina/calais door strips/trims?
    hello,
    i have a found a berlina/calais wagon at the wreckers with the 2 piece door trims (plastic bits on the outside oof the doors ) and just wanted to know what tools i'll need to take them off? And will wagon trim bits fit on a sedan?
    cheers, Pat
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME Stewart1000 Executive
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    not sure if they fit, maybe get them off and see if they match up with a sedan at the wreckers.
    just an idea, try fishing line, and slice through it. might have to use it like a sa, not sure.
    i think if you could get one there and power it, a hot air gun would make the job alot easier.
    good luck, let me know how well the line works as i need a new mould for my vl
    my web site
    stuff on the XF throttle body conversion, calais interior and lots of other junk!
    phat_com's Avatar
    Jan 2006
    ok, I tried to pull them off, but it didn't work. If you just have the one's that are like a big as your palm then just pull on them and they will come off and for the little ones behind the wheel i used a coat hanger to pull them off.
    Cheers for the info and i'll post me info when i try.
    phat_com's Avatar
    Jan 2006
    bump someone must know for sure how to get them off, I had a go with fishing line and it just broke (50lb mono) so yea?
    '86 VL Executive N/A, '88 VL BT1 Turbo
    Aug 2006
    You really only need 2 tools, a 2" paint scraper (to lever up the mould), and an extending blade knife (to cut the sikaflex off). Most trims are either glued (sikaflex) or d/sided tape, or both. Mine were s#itloads of both
    First, the door strips have a pin on each end (try not to break it) Lever the mould up just enough to get the knife blade in and start slicing, moving the scraper along as you cut. Cut from the top first, then along the bottom. Depending on how much sikaflex is on it, it might take 5 minutes or twenty minutes. Took me 1/2 hour to do all four doors of mine.
    Hope this helps.
    phat_com's Avatar
    Jan 2006
    ok I'll give that ago and post how i go tomorrow or the next day.
+ Reply to Thread
  1. Removing door/guard strips VR/VS
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-12-2007, 08:51 PM
  2. Help removing plastic door strips
    By dean_jely in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-11-2007, 08:34 AM
  3. Removing door side strips
    By karlos_1984 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2007, 10:40 AM
  4. Removing Door Strips
    By vxsenator in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-03-2005, 04:50 PM
  5. Removing Door Trims on VK Berlina
    By tr3nt in forum Car Audio
    Last Post: 28-12-2004, 10:19 PM
