Results 1 to 3 of 3
Thread: fuel problems
    VP Executive V6
    Jun 2006
    Default fuel problems
    well i had problems with the fuel injectors which got bunt out for they were leaking i replace it with reconditions injectors sience then it only ideal for a short time and dies, and cant revep it. I change out the fuel filter and replace the fuel pump, still no luck can any body has any idea how to trouble shoot this thing to get it going. thanks.
    Holdfast is offline Donating Member
    VE & VL
    Jan 2005
    Try erasing the memory on the computer but before you do check all the connections are tight.
    VT SS
    Feb 2006
    so the car runs ok for short time? if its stalling when it gets hot but runs fine when its cold it the crank angle sensor, and while your at it do this......clean the little contacts inside dizzy cap, they get white powdery stuff on em from the rotor button spark, scrape em with a tiny screwdriver, be careful though, they are fragile, also where the wire plugs to top of dizzy (crank angle sensor) do the same with screwdriver to contacts and spray with wd-40, crc... etc etc.....do this to all unpluggable wire connections to assure good electrical contacts...p.s. disconnect the negative battery terminal first........my nans r31 was runnin like a pig, done this to it, now runs perfect again, mechanic told her it was head gasket, ha ha ha, bloody mechanics, just saved her hundreds. another thing....make sure your battery has good terminals and contact, as bad battery contact will restrict the power, usually earth terminal is the culprit, make sure earth wire is not hangin on by couple threads too little things like this make alot of difference, i reckon anyway, some people will probably disagree, but try it, and see
  1. Need help with VK duel fuel, it's got quite a few problems
    By V8commodore_chick in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-08-2006, 08:58 AM
  2. Fuel problems
    By h2obro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-11-2005, 08:39 PM
  3. fuel problems??!!!!
    By bitch in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-09-2005, 10:54 PM
  4. Fuel supply problems .
    By Triox in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-04-2005, 06:16 PM
  5. Fuel Problems
    By VBSL79 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-12-2003, 01:43 PM
