Results 1 to 6 of 6
Thread: blue grey smoke on starting
    vl berlina wagon 6cyl
    Jul 2005
    Default blue grey smoke on starting
    I now have a problem with a big cloud of exhaust smoke, blue grey, when starting up and giving engine a rev
    doesnt seem to smoke otherwise
    the sump oil level was a bit high so I lowered it
    I replaced the PCV valve aned checked that the connecting hose wasnt blocked but I still have the problem
    the engine doesnt seem to be using oil
    any suggestions?
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Arrow
    Quote Originally Posted by harry3 View Post
    any suggestions?
    Valve guide seals will do that...
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    Jul 2005
    are these seals made of metal or something else?
    might some engine leak stopper additive have an effect
    theres a big amount of smoke, but only on or shortly after starting up, sometimes happens while driving off
    dreamcatchu's Avatar
    dreamcatchu is offline sick puppy
    VC Commodore
    Sep 2004
    Bundaberg qld
    The valve stem seals are rubber, you need to dismantle the head generally to replace them, but u can get a small spring compresser that when used in conjunction with an air compresser you can replace them with the head still bolted on, could even be the stem guides are worn and allowing the oil to run past and into the combustion chamber, a stop leak formula won't generally stop it due to the fact that it is caused by the oil running down the stem once the motor is shut of
    VY S2 Berlina
    Jul 2005
    Wide Bay, Queensland
    yea sounds like valve stem seals, its probably better to take heads off (if you can and have the money) and replace head gaskets as well, a gasket kit doesn't cost that much, and piece of mind is good too
    Jul 2005
    thanks, I guess the oil is leaking into the cylinders after shutdown as this would explain the big cloud on starting as its burnt off
  1. blue smoke
    By VH camping in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-09-2006, 06:57 PM
  2. VS V6 Blowing Dark Grey Smoke
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2006, 02:51 PM
  3. help.. slight blue smoke from 5L ..
    By jim898 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-01-2006, 06:02 AM
