Results 1 to 2 of 2
Thread: air cond vacuum problem
    vl berlina wagon 6cyl
    Jul 2005
    Default air cond vacuum problem
    my factory air cond suddenly stopped working
    elleries says to check a check valve on the vacuum line from the manifold to the vacuum tank
    I cant find this valve
    anyone know where it is or what it looks like
    some of the air cond controls are vacuum operated
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    The vac tank is the little ball at the front of the car, so going by that there should be a hose coming off it running to your manifold? I didn't know that was the case but fair enough if it is.
  1. airflow controller not working - vacuum cluster problem?
    By catalyst55 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2006, 01:18 PM
  2. Vk Black Vacuum Problem
    By Berniebgf in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-11-2005, 10:04 AM
  3. Vacuum problem? with feet/face/demist mode unit
    By gaza1970 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-10-2005, 10:25 AM
  4. A/C Vacuum Problem
    By nobby in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2005, 05:51 PM
  5. VP Air Cond.
    By brad_m_is in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-06-2005, 10:55 PM
