Results 1 to 10 of 10
Thread: water from areial
    vl berlina wagon 6cyl
    Jul 2005
    Default water from areial
    I heard that on the VL, water can leak in thru the radio aerial base, run along the cable and drop down onto the ECU computer......
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    yeah pretty unlikely... i shaved the hole on my old vl... who listens to radio anymore?
    Going where no late model stato/caprice has gone before.... GAME ON!!
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    I haven't heard of that before but any things possible with the vl, one I had recently had rust damage on the ecu but more likely from windscreen rust! I have an 88 fivespeed that has got plastic taped around the ecu, (well protected) any water in that one would also be the windscreen.
    Nobody wants to play with me
    Jul 2005
    yes duct tape or similar seems a good idea, someone said use a plastic bag but this cant be got over it on the side next to the car
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    plastic bags are ideal. get to your ecu THEN 1. remove screws retaining lower mounting bracket 3-5 screws remove mounting bracket 2.move ecu downwards to disengage from the top bracket. no need to disconnect any harnesses! bag and/or tape it up. 3. replace it in reverse NOTE, making sure the harness dose not get caught between the ecu and the bracket! very easy job.
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    but would be baging it be dangrous? im just assuming that the ecu will generate heat like most pcs do or am i wrong
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    walesy's Avatar
    Jun 2005
    Perth SOR
    thats what i was thinkin... the bag would melt..
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    So you're worried about the water running in from the aerial itself, then along the aerial cable and dropping off the sheathing onto the ecu?
    If so, why not just put a loop in the aerial cable inside the panel? Water cant travel uphill
    The Red Dot indicates the entry point
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    Interesting! what sort of temperatures are you talking about? considering the ecu is behind an insulated panel in a vehicle that would easily reach 80deg on an 35deg day, the five spd I have is wrapped in plastic and I can only assume it's been like that for many years
  1. water disappearing - water pump - how to change?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2008, 01:30 AM
  2. air con water?
    By mark_1000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-01-2007, 10:18 AM
  3. areial trouble!
    By Snotty in forum Electrical Wiring / Questions
    Last Post: 30-05-2006, 11:06 AM
  4. car covers . water proof vented vs water resitant non vented
    By justbad4you in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-10-2005, 01:20 PM
  5. Water in Car
    By blue alliance in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-07-2004, 05:41 PM
