Results 1 to 4 of 4
Thread: vl rb30 5 speed gearbox parts? still available?
    HZ Sandman Ute, HZ GTS, VT Senator
    Apr 2006
    Default vl rb30 5 speed gearbox parts? still available?
    are the gears still available (apart from wreckers)? if so does anyone know much much they charge?
    also sincros???? i believe they are no longer available also. is this right?
    cohn's Avatar
    cohn is offline VN28CN
    VN Calais Turbo
    Nov 2004
    Penrith
    yeah, they should be, i looked into rebuilding mine, i got quoted 375 for the synchros and stuff, and the same for the bearings, interlocks and detents, roll pins etc.... basically everything to rebuild it except the gears, shafts, shift rails, forks and housing.
    About 800 for everything to make it a new box, but that was through a guy i know through work. so i reckon about a 1000bucks for everything or 500 for a minor rebuild, depending on whats stuffed and what need to be replaced.
    but if you want a box to take a bit morre of a beating i would recommend loking a a r33 gts-t box conversion.
    Soon to be back on the road, Turbo VG.
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    I believe the standard rb30 5spd (MF5) is better known as the aussie 5spd and all parts are no doubt still available turbo model MX7 was made for turbo by the japs probably very similar to the r33 gts-t box
    Nobody wants to play with me
    Apr 2006
    rang up holden yesterday and they said that nope cant buy gears or even syncros anymore.
    cheers
    jason
  1. ??? RB30 manual gearbox ???
    By cohn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-12-2010, 05:31 PM
  2. t5 speed gearbox conversion setup & vl-vn parts
    By ma77es in forum Parts And Other Items For Sale
    Last Post: 23-04-2008, 06:08 PM
  3. WTB: VL RB30 manual 5 speed Gearbox, Sydney
    By cohn in forum Swap / Wanted to Buy / Trade
    Last Post: 26-02-2007, 09:13 PM
  4. VL rb30 block to rb20 gearbox
    By Slipinit_sideways in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-09-2006, 10:28 PM
  5. rb30 gearbox conversion
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-05-2006, 07:02 PM
