Results 1 to 11 of 11
Thread: VL 5litre on NOS
    VZ SS 5.7L
    Jan 2007
    Default VL 5litre on NOS
    Im going to rip the 5 litre and traumatic out of my VL and whack it into a LH torry <--- I reckon the torry will go faster
    I want to put the bottle on it but I dont know much about it.
    I was looking at the NOS Sniper kit as a starter. I dont know what has been done to the engine but its best time down the 1/4 in the Vl is a 14.66 running 3.08 spooled diff.
    Can anyone help ?
    VT SS S2 A4
    Aug 2005
    VZ SS 5.7L
    Jan 2007
    Quote Originally Posted by rb26dett View Post
    With that sort of time it has had some work done to it.
    I know its had some work to it. I dont know what because I bought it like it is.
    I want to know if anyone has done it and how to do it. Is there anything I need to do to the engine to try keep it in 1 piece and whats a good starting kit to go with.
    VT SS S2 A4
    Aug 2005
    VZ SS 5.7L
    Jan 2007
    Ahh not sure yet, thats why im asking. whats a good place to start, I was thinking 100-150hp kit
    SICK SS is offline 7L 427ci BABY
    427 ci vu ss a4 ve ssv a6
    Jan 2007
    central queensland
    mate with just the weight reduction from vl to torana it will feel like its already got a shot of nos up its @rse i would see how it goes first before deciding weather or not to nos
    VT SS S2 A4
    Aug 2005
    I think you would be better off starting with a 25 - 50 shot. I would be getting the motor inspected atleast before trying to give it a 100 or 150 shot.
    VZ SS 5.7L
    Jan 2007
    Quote Originally Posted by SICK SS View Post
    Its going to get NOS regardless, Just how much is the question. Its not a daily driver, its just something to run 1/4's with and fry some tyres.
    Can you get a 25-50 kit ? The smallest I saw was the 100-150 kit, only $480 too.
    Im going to put a gasket kit through the engine as a bare minimum before putting it in the torry. Might check out the bearings and see if they are in good shape when I change the sump over
    VT SS S2 A4
    Aug 2005
    Yep, can get a 25. Have seen it being installed into a standard V6 Magna VRX.
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    You will want an ARP head stud kit so the heads dont lift from the block when you hit the gas. The NOS kit should come with different size nozzles which give different size shots. IMHO 50hp is a good figure for a daily driver and will be healthier for your engine than say 100-150 hp shot.
    You wont find much of a weight saving in going from a VL to a LH I used to have a UC and for the size of the car they are quite heavy, say 1350kg for a VL 5.0 and 1250+kg for an LH 5.0, Plus the VL has the slippery shape while the torana has the aerodynamics of a wallunit. I do love the torries but having owned both I know which is better to live with.
    ========My Statesman 20's Mafless and 3.9's========
    VZ SS 5.7L
    Jan 2007
    Cheers for the info.
    I will order a set of studs for the heads, Do I need to run different head gaskets ?
    The torry is definately lighter. it has had all the trim, carpet and anything else that we thaught had any weight to it. To do that to the Vl its alot of work. We figured it was easier to rip the 6 out of the torry and chuck the 8 in.
    Although the Vl is a nice ride. THe torry is going to do it in style..
  1. VR Calais 5litre help??
    By gupatrol in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-12-2007, 01:41 PM
  2. rebuilding vn 5litre
    By lowrida56 in forum V8 Development and Modification
    Last Post: 06-11-2005, 02:26 AM
  3. converting a 5litre to gas
    By lowrida56 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-09-2005, 10:22 PM
  4. Vt V8 195 I 5litre V8 Bcm Problems
    By Rock56077 in forum Electrical Wiring / Questions
    Last Post: 29-02-2004, 09:33 PM
