Results 1 to 7 of 7
Thread: How can I tell if its LSD?
    VT SS
    Feb 2006
    Default How can I tell if its LSD?
    I got a vl turbo, not running, how do I find out if its lsd, if i turn the drive shaft, should both wheels turn the same way or what? any advice appreciated. thanks
    VT SS S2 A4
    Aug 2005
    pr0n's Avatar
    pr0n is offline It's A Me ' MARIO '
    03 VY II S V6
    Dec 2006
    Gladstone
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    Quote Originally Posted by pr0n View Post
    plant your foot if theres a burnout behind both tyres u got lsd
    no if you thrash a single pegger enough they will start to cut constant 2's... then blow up, then weld it up and keep breaking welds, then buy another diff and spool it... well thats my story anyways...
    Going where no late model stato/caprice has gone before.... GAME ON!!
    '97 VS II Statesman 5.0L 5-Speed
    Feb 2006
    Radelaide
    if you turn the shaft both wheels will turn the same way if its LSD or not.
    jack the rear of your car up by the diff, spin one wheel with your hand, if the other is spinning the same way it's LSD. if the other one spins in the opposite direction it's a single spinner.
    when i bought my replacement diff, i turned the shaft and both went the same way i got all excited before i realised i turned the shaft not one of the wheels :P
    VT SS
    Feb 2006
    vl berlina wagon 6cyl
    Jul 2005
    the surest way is to jack up one rear side and place a piece of wood holding the wheel off the ground in a way that wont hurt anything if the car moves forward, then attempt to drive forward, if it moves theres a LSD thats working, many LSDs eventually stop working
    drive a tight circle on a sealed road and check for bumping or windup in case the diff is locked up
