Results 1 to 4 of 4
Thread: Words of experience please
    ajedge is offline ajedge
    86 VL Calais 5.0
    Jan 2007
    Western NSW
    Default Words of experience please
    Hi Guys,
    I am new and this is my first post. I have recently picked up a 86 VL Calais 5.0. The engine seems to be in excellent order but the "cosmetics" need a heap of work - inside and out. As an amatuer, I am hoping someone may be able to help me with the following;
    Rear brake lights - I have replaced globes from inside boot, but bottom half of brake lights is still not working. Are more globes required lower, or is this a wiring problem?
    Paint work on the roof and rear (boot & spoiler) is peeling away pretty badly. I am not keen to respray at this stage. Is it wise to peel the remainder away, or should I let nature take its course for the time being?
    Air conditioner is blowing hot air. Next to no air is coming through dash "side" vents. Is this a a/c gas problem? How about the vents? Is there an easy way to allow air to flow more freely?
    If I pull the park brake on too full, it is near impossible to release. Is there an easy way to adjust this.
    The electric windows, cruise control and electronic headlight covers?? have been previously disconnected. Where do I start looking for disconnected wiring for both of these?
    That's enough for now. Thanks heaps to anyone who can help out a first timer looking for a new hobby - 308 motors and their shells!
    vl berlina wagon 6cyl
    Jul 2005
    welcome
    if the paint is metallic this usually didnt last long
    my air cond has the same problem maybe a fault in the vacuum control system a valve on the vacuum line from engine to vacuum tank behind front bumper can jam, but I cant find the damned valve and nobody here seems to know where it is
    might help to lubricate brake lever ratchet and adjust cable under the floor, use locktite as the double locking nut system seldom works
    check for rust around the windscxreen and poorly done rust repairs, using a magnet
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    I don't remember the tailights having upper and lower globes just a central one for each lense, leave the paint that has faded in place as this will protect the surface underneath (to an extent). My side vents don't seem to work either, my aircon is getting removed shortly to free up some rpm so I'm not really phased about vents (aircon hasn't worked since I got the car anyway). Sounds like yours just needs a re-gas, as for the front clip popups there will be a plug that is disconnected (take off the front bar and grill and all should be revealed).
    ========My Statesman 20's Mafless and 3.9's========
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Arrow valve
    Quote Originally Posted by harry3 View Post
    welcome
    Harry the vacumm valve is just behind the brake booster, look 4 the vacumm ball under the guard and follow the line up in to engine bay (next to battery) and it goes under the washer/overflow and comes out near the back of the booster..
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
  1. New Words for 2007
    By bazcom in forum Jokes/Humour
    Last Post: 03-10-2007, 07:44 PM
  2. Eight Words with two Meanings
    Last Post: 03-10-2007, 05:25 AM
  3. Foolish Words...
    By fourstar82 in forum Jokes/Humour
    Last Post: 14-02-2007, 09:13 PM
  4. New words
    By DavidPartay in forum Jokes/Humour
    Last Post: 16-09-2004, 09:41 PM
