Hey, got yet another problem with my VL. Recently after a good burnout competition. The motor has developed a rather loud ticking sound at light to half throttle. When I take off normally, if I dont shift then it sounds like a very fast tick. This is not the problem but this is what it sounds like. You know the way the injectores tick at idle??? Its about 3 times as loud and heaps faster. The ticking speed matches the engine revs. I think I got a loose valve. I can't notice a power loss or anything. The oil was changed 2 months ago. Along with the oil filter... WHAT IS MY PROBLEM??? I don't have an oil pressure gauge, I know I need one and I have the dual pillar pod setup, I just dont have any gauges to put in it... HELP![]()
Maybe you blew out your exhaust mainfold gasket. That will tick with the engine revs. Get a piece of garden hose and hold one end to your ear and with the other end follow around the manifold where it meets the head, most likely it will be the back that has blown out if indeed this is the problem.
if it follows the rev range its highly likly to be a sticky lifter or two,
try new oil with the lifter free adative stuff from nulan
if that does not work after the desinated time it states on the bottle then there is either a problem getting oil up to the lifter or they are well and truly stuffed, just replace them.
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
Isnt the RB30 overhead cam? No lifters.
yes it is over head cam, but i belive there is still lifters there, im almost positive about it
edit: well here you go a guide how to clean them, curtosy of calaisturbo
http://calaisturbo.com.au/showthread...hlight=lifters
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
my vl done this lmao it was all the lifters/tappets or whatever they are called they where stuffed guy i sold it too told me that he got new ones from wreckers and says it runs nice and smooth now
[SIGPIC][/SIGPIC]
shane if ya need a head let me know. have a brand new (not reco, brand new) here and also a couple of s/h ones.
cheers
jason
I think all RB series motors have them.
Yeah its only 2 valves per cyl as well, but it still gets along quite well and was space age in its day and has even more technology than an ecotec. Things like self diagnosis and the ecu's ability to tune the fuel/spark up to 100 times a second so the mixture is always perfect or adapted to your driving style are good things.
The rb's have hydrolic lifters that run from the camshaft and these get gunked up from years of abuse etc.
