Results 1 to 7 of 7
Thread: starter motors
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    Question starter motors
    I got the new sc mag today and it has a vl conversion list of things you need it says you need a manual starter motor dose any one Know the difference man/auto? I have a manual which I put a starter from an auto in it dosen't seem any different and it works.
    Nobody wants to play with me
    POVRTY's Avatar
    POVRTY is offline building 5L VB TH 400
    VE SSV 6SPD WGN
    Dec 2005
    taree nsw
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    the list for auto to man conversion from the sc mag is as follows
    clutch hydraulics, master + slave cyl and lines connecting both,
    a manual spigot bush,
    clutch fork and thrust bearing
    manual pedal box
    manual computer
    manual tailshaft yoke
    gearbox mounts
    manual starter motor? (questionable)
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    there are a few other things required eg,
    floor shifter plate,
    manual centre console,
    I have been looking for more info on this conversion and there is a how to thread on this forum which has been helpful there is also another how to on the calaisturbo.com forum ( not just for calais turbo) which is also helpful. do a search to locate them the calaisturbo one has som pics available. sc mag is going to publish the how to in issue 123. get your info from a few sources as some can be mis under stood or misleeding, hope this helps , good luck!
    p.s. I have not done this conversion yet there are some users on here that have who also maybe able to help!
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    i think there was a mistake in the magazine. the starters are the same. only the turbo ones are different cos of the bigger flywheel.
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    just for the record after contacting feedback of sc mag they said everyone they spoke to told them they need a manual one even though when they lined them up they appeared exactly the same even the part no. was the same they said it must be different torque ratios?
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    Quote Originally Posted by jatsvl View Post
    F*cking idiots. Don't they do research. If the part numbers are the same don't you think they would have realised that they are the same. They mustn't have specified the car was NA.
    Another tip is to use the NA flywheel instead of the turbo one with the rb25det gearbox. reason being you can get higher rated clamping pressure clutch kits for the skyline over the rb30et.
  1. vn starter motors
    By HÝPÕ-5L in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-09-2007, 06:44 PM
  2. Reduction / Hi Torque Starter Motors
    By Rossco in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-12-2006, 09:53 AM
  3. v8 starter motors
    By VN-SV-89-LE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-08-2006, 09:56 AM
  4. starter Motors
    By Disturbed_vegeta in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-08-2006, 08:03 PM
  5. vl 6 cyl starter motors
    By mems84 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-11-2004, 04:24 PM
