iwas wondering if there is any off the shelf cold air intake system for the vl. inow they make them for over models like the vn/vp becuase my uncle got one for his vn thanks for reading my post any info would be appreciated
there is no off the shelf CAI for the vl like the model from vn onwards.
this is because the nose cone on the vl covers the bonnets front and disalows air to flow in under the bonnets nose like the vn onwards,
there is the pvc pipe trick under the guard which is illegal as you have to cut the guard but it causes a ram effect as it pops straight up into the air box.
i have this intake set up on mine with a k&n panel filter, the mouth of the box cut open wider and the mesh on the air flow meter removed and a custom pipe i made out of 2.5 inch exhasut pipe between the throttle and air flow meter,
might not be a huge power gain but its better then nothing. and with the exhaust it and other stuff it will make a defent improvement
heres a pic of my engine bay so you can see what i mean by pipe, was dirt then cleaned it all now
http://forums.justcommodores.com.au/...3&d=1167283410
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
so is there any other option like a pod filter instead of cuting the body im awear that a pod sucks the hot air from under hood so its not a dense as the cool air
only real gain that is avalible from a pod is if you build a heat sheid all the way around it, with its picking up from behind the headlight
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
the front snorkel fell off my filter box making the intake larger, which may help perhaps
any air intake from under the mudguard risks severe enine damage from hydraulic lock if crossing a creek and sucking in water
who the hell crosses a creek in a VL? If you cross a creek then you're just as likely to suck water in with a standard airbox setup too. IMO don't cross creeks in a VL.
love that heat shielded podfor MORE POWER!
and no defect and any body crossing a river/creek in a vl deserves what will happen
leave that to morons and higher vehicles.
Nobody wants to play with me
Here is my old post about this method i have chosen(scroll down till u c mine with Pics,good luck
air intake... BEST method
Snorkel and AFM screens off = 32% off intake air restriction
Last weekend i put a Pod filter on mine and also put in a quick heat shield (screwed an old heat shield from the exhaust so that when the bonnet goes down the pod is shielded from the heat from the engine compartment as well as a bought one (well, i think so)
Instantly i noticed throttle responsiveness went up all the way through the range. This is probabaly due to the old filter having a date of 99 on it and it being almost black when i took it out.
Originally Posted by Reaper:
Originally Posted by Jecs:
I've noticed that there are numerous members who comment on the major increases in power/throttle responsiveness post the introduction of a CAI. This may be true to some extent....but to be honest I think a large part of it is psychological!
After doing mine, the greatest benefit i have found is the fuel economy. Instead of my maximum 330km per tank, I'm getting an easy 450km off a tank.
In this day and age, thats not to be sneezed at
Not really alot to be jealous of mate, just some stainless steel.
Just looks real neat. Unfortunately, I inherited my ride in a rather sad state..
I was looking in the engine bay yesterday considering my options for getting colder air into the engine.
Looking at it, there is a gap between the radiator shroud and the front of the block. Now, theoretically, could not a pipe be run through that gao and then out a hole cut in the plastic lower air "ram", a slight turn at the end exiting in a flat but long fitting that is no deaper than the air ram itself. then cutting a corresponding chunk from the front of the ram, so that air rushing underneath the car is directed towards the intake???
Just cut the hole
Ive got my PVC pipe running under the air box to the front bar with a wide mouth on the end and some thin stainless mesh over it so no leaves get in.
yeah most ppl do this bloke,
..... soz man have a look at the date of the thread 3 years,
welcome to Jc :P
