Results 1 to 14 of 14
Thread: Advice
    kel
    kel is offline VL's are HOT!
    Holden Commodore Vl
    Feb 2007
    Default Advice
    Hi everyone, Ive just had my car re sprayed, a kit put on and 17" mags, now im wanting to get it sounding as good as it looks. i was thinking new exhaust system and extractors. any advice on what sort or what else i can do will be muchly appreciated thanks,
    Kel xox
    P.s shes still a stock 6
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    try pacemakers hi flow cat and a resonator, hanson exhaust in maddington will be able to help u out more
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    http://www.youtube.com/watch?v=n3bXNdhAF7g
    Unsure of the extractor brand off hand, but pulled them off a VL i got for $300
    fitted to a 2 1/2 inch exhaust with 2 1/2 inch dump on the end.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    kel
    Holden Commodore Vl
    Feb 2007
    vl berlina wagon 6cyl
    Jul 2005
    I wouldnt bother with extractors, Ive been told they give no benefit for street driving but make the engine compartmant lots hotter and the car lots more noisy, also much bashing is usually needed to make space for them and they always need leaks brazed up after a while
    a good exhaust place will have worked out a system that gives the sound you want
    extractors are for show, not go
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    Quote Originally Posted by harry3 View Post
    TOTALLY FALSE! your engine will run much cooler and the noise level is not much greater recommend fitting a resinator as you were previously advised the notion bashing your car to make them fit is just ridiculous there is more than enough space for a supplied bolt on set. cast iron manifolds trap heat and in turn break mani studs which is common on the vl also flange gaskets require replacing, with extractors no more broken studs nore flange and an increased power level
    belive those who have them not those who "HAVE BEEN TOLD! and don't approve of mods"
    Nobody wants to play with me
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    What planet do you live on????
    Extractors give you more torque, better economy and make the engine run more efficiently. They also dissipate the heat better, and eliminate the broken stud problem that the RB30 has.
    The only thing I would say is not to fit a hi flow cat, total waste of time as the original cat does the job.
    Sabbath''s Avatar
    Jul 2006
    I wouldnt bother with extractors...
    Of course...how stupid of us, we've been putting aftermarket gear on our cars that will actually impede the performance...
    I put my extractors in myself, didnt need to take to any part of the engine bay with a hammer. They fit nicely in, and even got the heat shield back in without having to cut any bits out of it.
    And also if he's after a system that gives him the "Sound" he wants then according to you maybe he should put extractors on because they make a stock 6 soooo noisy
    VL Wagon
    Jan 2007
    Quote Originally Posted by kel View Post
    Kel xox
    Post some pics of ya car up, i'm interested to see what it looks like.
    cheers
    smockyjnr@gmail.com : MSN
    POVRTY's Avatar
    POVRTY is offline building 5L VB TH 400
    VE SSV 6SPD WGN
    Dec 2005
    taree nsw
    any1 wanna buy some vl extractors? dont know what tipe they are they came stock on a calais ive been wrecking..
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    VL's never came stock fitted with extractors. If yours has them then they were fitted aftermarket.
    POVRTY's Avatar
    VE SSV 6SPD WGN
    Dec 2005
    taree nsw
    1988 VL commodore
    Feb 2007
    sydney
    They should have a badge or stamp on them somewhere. If not they may just be a standard manifold exhaust.
    [SIGPIC][/SIGPIC] MYSIGNATURE.COM
    POVRTY's Avatar
    VE SSV 6SPD WGN
    Dec 2005
    taree nsw
    there deffinatly extractors
  1. bit of advice
    By pitt88 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 02-04-2007, 05:47 PM
  2. Vx advice
    By VRV666 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-12-2006, 10:22 AM
  3. VG Ute need advice
    By sumna in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-11-2005, 06:13 PM
  4. Need Advice
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-08-2005, 10:55 AM
  5. Some advice please.
    By trucker in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-06-2005, 07:54 PM
