hi was wondering if it would be possible to change from the single lagging turbo to twins but is was think if it was possible to mix a big turbo with a smaller one to try to minnimise the lag. thanks all info will be appriceated![]()
LIKE MY BIG RED WRITING?
you can do it like you said with one smaller turbo and one bigger...i think the rb26dett it set up liek that
thanks mate i didnt know if the bigger turbo would make the smaller bypass its limits at the hi revs with big boost causing premeture wear or damage or if itwas even posible
i thought rb26's had two t28's the same size.. i would like to see someone do it to know how it went. it can't be a bad idea.
and no i don't like your big red writing.. lol
running two diffrent sized turbos is possibly, bmw have developed a new car which is twin turbo running two sizes, it was designed to have no lagg. it makes 300hp i think if i recal correct
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
i like lag gives me a chance to regain traction between gear changes lol
wrecking VL COMMODORE 5 speed
FOR SALE : supra 5 speed box suite holden v8 $800
actually when you think about it, with a twin setup you don't need overly large turbo's so the lag wouldn't be as bad as a larger single setup anyway... just ahve to be choosy with your turbo selection
i am running a TRUST T88 its but takes heaps long to come into play
shortening your intercooling plumbing can make a big difference. getting an a/m plenum that faces foward straight to intercooler then to turbs gets rid of a lot of plumbing and also lag.....
