Results 1 to 12 of 12
Thread: urgent help needed!!!
    VT wags
    Jan 2007
    Default urgent help needed!!!
    Hey all
    i urgently need some advice about my Vl wagon.
    A few weeks ago i noticed the dreaded milky sludge in my radiator...and under my oilcap. naturally i thought it was my head gasket. So last weekend i changed the gasket, new oil, flushed the radiator with new coolant etcetc. Today i open my oil cap to see more cream coloured sludge underneath it. I have no idea what this could be. Obviously the oil is mixing with the water somewhere but i have no idea where it is
    please help!!!
    thanks
    Burt_vn's Avatar
    Burt_vn is offline Back in the game
    VG V8 5spd, 400hp 5spd soarer, vq stato
    Jan 2007
    Gold Coast
    possible corrosion of one of your oil/water jackets in the head, possible warped heads..plenty of possibilities. Cant tell you over a forum mate.
    VG ute, 5.0lt, 5spd, twin exhaust, cam etc.
    VQ stato, 5.0lt, auto, pretty stock
    TT Soarer, 400rwhp, 5spd, lots of mods.
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Unhappy
    Quote Originally Posted by speedracer006 View Post
    Hey all
    please help!!!
    thanks
    Yeh that's a ****
    Head cracked or corrosion has eaten through (Bugger)
    Try Chemi Weld It comes in the glove box ready if you drive a ford
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    is the cream back in the radiator too? did you give the engine (oil flush treatment) a flush? is your radiator level droping? I don't disagree with the above posts but if u didn't flush the engine then there would still be water in there which would cause condensation build up on your oil cap.
    Nobody wants to play with me
    VT wags
    Jan 2007
    i havnt flushed the engine, but flushed the radiator real well, i also thought it coulld be that till i realised that my radiator level was also dropping.
    A new head may be in order then??? or is there anything alse i can do?
    damn right its a ****
    cheers for any help guys
    1988 VL commodore
    Feb 2007
    sydney
    To check if you flushed the radiator exactly the way it is supposed to be done, check here: http://www.vlcalais.com.au/showthread.php?t=607
    [SIGPIC][/SIGPIC] MYSIGNATURE.COM
    lc torana. vn v8. ke30.mazda 1300.
    Mar 2006
    chuck a new head on it there cheap as probly pick one up for 40-50 bucks
    also did u skim the head when u replaced the head gasket?
    wrecking VL COMMODORE 5 speed
    FOR SALE : supra 5 speed box suite holden v8 $800
    Jun 2005
    South OZ Adelaide
    Arrow
    ChemiWeld
    someone on another site said
    Re: Help.....head gasket ? Thu, 05 June 2003 00:15 Go to previous messageGo to next message
    Regardless of what ppl will say Chemiweld is a quick fix, but a great one. Sometimes it works, sometimes it doesn't.
    If it does, your laughing cause it cost you bugger all.
    If it doesn't, then it doesn't..
    If Leak in the gasket is small enough, you might be ok. Make sure you follow the instructions exactly.
    It's worth a try buddy
    Ex apprentice..
    Try it as mates have fixed even cracked blocks with it...
    Do read the instrutions first..
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    If you didn't flush the engine, there is probably still water in there and it will leave the milky residue under the oil cap. After a couple of oil changes this will go away. I'm assuming you looked at the head to check for corrosion between your oil and water galleries. Get a pressure test done on your cooling system, this will tell you if water is still escaping somewhere, before you go buying other bits you may not need.
    VT wags
    Jan 2007
    yer i skimmed the head for about half an hour haha.
    ill look into the chemiweld thing and see how it goes.
    cheers
    HZ Sandman Ute, HZ GTS, VT Senator
    Apr 2006
    if ya need a head let me know. i have a couple. one brand new (not recon) one. also other s/h ones.
    cheers
    jason
    POVRTY's Avatar
    POVRTY is offline building 5L VB TH 400
    VE SSV 6SPD WGN
    Dec 2005
    taree nsw
    chemiweld can block more than a leak............even using it as directed is a risk
  1. Urgent help needed!!!!
    By 4PLAYN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-09-2006, 11:28 PM
  2. urgent help needed
    By vrberlina5sdp in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-03-2006, 07:53 PM
  3. Urgent Help Needed Now!!!!
    By Keesh in forum Electrical Wiring / Questions
    Last Post: 19-02-2006, 08:49 PM
  4. Urgent Help Needed
    By Holdenboy_VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2006, 07:16 AM
  5. Urgent help needed
    By monaro04 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-06-2005, 12:10 PM
