Page 1 of 2 12 LastLast
Results 1 to 25 of 50
Thread: Unconventional idea for VL project, VS/VL hybrid
    Marco-EFIVL's Avatar
    Marco-EFIVL is offline Now driving R34 GT-T taxi
    Nissan Skyline, R34 GT-T (RB25DET NEO) sedan
    Aug 2005
    Perth Balcatta/Hyden (Wave Rock)
    Exclamation Unconventional idea for VL project, VS/VL hybrid
    I've been toying with this idea over the summer and I wonder if anyone else here thought if it would be both reasonable and possible.
    Get this:
    Bottom end from VL motor (RB30) - (Larger capacity than other RB motors).
    Head from RB26 - VVT, Twin Cam, Four Valves PC, great breathing characteristics, more power, more efficient.
    Placed in a VR or VS body - I do a fair bit of driving and my current chassis/floor pan is rooted, so either way, I need a new shell. I like the shape of these two models, what are the mechanical pros and cons of the VR/VS range?
    Later mods; Body kit, twin turbos, 18" Wheels with bigger brakes, after market lowered springs & shokies, short shifter, head work, forged pistons, after market cam, beefer injection pump and bigger fuel lines, better ignition leads and spark plugs, CAI and pod filter. Of course, I nearly forgot, a decked out sound system for my ride!
    So, does this project have merit? What I'm thinking is getting a rolling body from the auctions, I've got the RB30 which I can/want to rebuild and my uncle has a 5 sp Nissan tranny from a 1999 R34 Skyline. Is RB26 head the best option? Most power? I'm guessing it will be more expensive? What is there availability?
    Help is much appreciated, cheers!
    Wagon_Wheel's Avatar
    Wagon_Wheel is offline Drop A Patch....
    Aug 2005
    Mt Martha, Vic
    cammed Vx ss m6
    Sep 2006
    seen one in street commodore magazines with a guy who had this done to his vl. i think he was also running 16+psi of boost
    lc torana. vn v8. ke30.mazda 1300.
    Mar 2006
    ive seen an rb20 in a vs commie before so fitting an rb30 is possible
    rb26de head is the best option
    single turbo over the twin id go for.... beter in the long run and less to unblot when u have to fix ****
    ive also seen an rb30det in a vn commodore
    your project has merit as long as u go ahead with it
    wrecking VL COMMODORE 5 speed
    FOR SALE : supra 5 speed box suite holden v8 $800
    vl commodore s2 rb30e
    Oct 2006
    i know of two hear in brisbane that have done that ones a vr or vs ute with a rb30 bottom end with a rb25 head with 411rwhp and that other one is a vs with rb25 in it cant remember hp but sound insane itsssss easy to do you just need a vl cross member
    VP Exec
    Jun 2005
    While we're brainstorming ideas, would a Nissan Patrol bottom end work with RB30/25/26 bits, particularly a 25 or 26 head? 4.2L, got to be good for off boost torque and getting onto boost faster.
    Holden VL Commodore
    Aug 2006
    South Australia, South East
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    People have been doing this for quite a few years put the twin turbo 2.5dett head on but with a single turbo the worst part of the whole conversion would be that the heads have no place for a dizzy because the skylines have a coil on top of each sparkplug and that cam angle sensor on the front of the head just need engine bay wiring probbably and an ecu out of a skyline these things can make over 1000hp with not to much work.Over here in nz it is hard to find the heads to do this conversion as lots of others have done it and they get bought up pretty quick.
    Aug 2005
    Speaking of, would it be better doing the RB30 bottom end with the RB26 head thing or would it be better to get a complete RB26DETT imported and just stoke/bore it out? On that note, what is the maximum that both the RB26 and RB30 can have their respective capacities expanded to?
    Mar 2006
    Quote Originally Posted by Marco-EFIVL View Post
    unlless u have upwards of 30 thousend just to get a stroker kit done id stop thinking there and stick with the good old rb30
    i think the first 1000hp skyline it was a blue godzilla.. he spent around 300,000 on it and i believe it cost him like 26 grand or somthing for hes rb26 stroker kit or some crazy amount of money
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    yeh theres is a vs wagon down here with an rb26dett in it...looks like a stock vs wagon with 17's... then pffftsh
    Going where no late model stato/caprice has gone before.... GAME ON!!
    vn commodore
    Dec 2006
    Quote Originally Posted by VLDavo View Post
    the stroker kit cost about 32,000 not installed and even then the largest that the car can be stroked out to is 3L
    better off using the Rb30 bottom end and a RB25 head as it requires less modification. however look how man VLT are under the 10s mark and most of them are single cam so unless your looking for an insanely quick car i see no need for the dual cam
    Aug 2005
    Why so much for a darn stroker kit for the RB26?
    My old man has a Datsun 260Z (Which is now considered vintage, being 30+ years old). To get a stroker kit for the L26 Motor (Forefather of the RB engine series) cost little more than $700 USD and that is also with a set of 89mm forged pistons (Which are in turn bored out from the stock 84mm pistons). I can't understand why it would cost so bloody much.... Could the RB26 be bored out at all?
    Speaking of displacement increases, can the RB30 be either bored or stroked out any more?
    VT SS S2 A4
    Aug 2005
  15. #15
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Quote Originally Posted by rb26dett View Post
    RB30 can not really be bored out anymore.
    Then how do you rebuild them? Like all engines you could easily take 30-40 thou' outta it.
    Please dont bastardise a VR/S tho!!! So many better options!! Why not turbo a 5.0lt?
    Selling FG G6E Turbo and buying a N/A Supra
  16. #16
    Aug 2005
    How is that bastardising the VR/VS? Ut is just something unconventional and not every-day, as well, I've already got an RB30 ready to be rebuilt, so it is also convenient. I love the good old Aussie V8, however, I like my straight sixes, be they BMW or Nissan, which in my mind, are two of the finest straight six motors to grace the earth...
  17. #17
    VT SS S2 A4
    Aug 2005
    Quote Originally Posted by AirStrike View Post
    Well I thought that they ment over 40 thou.
    Should have made myself more clear.
  18. #18
    Aug 2005
    Gah, I don't think I'll even be able to use my bottom-end, my crank and harmonic balancer are shot... :/
    Still, I'm liking this idea, would it be better tho to leave it N/A? Or forced induction (Turbo)?
  19. #19
    walesy's Avatar
    Jun 2005
    Perth SOR
    YAWN... vl turbos are done to death!
  20. #20
    VT SS S2 A4
    Aug 2005
  21. #21
    walesy's Avatar
    Jun 2005
    Perth SOR
    well you can when it becomes so popular its boring...i used to want a vl turbo when i was younger but then i saw the light and thought... why be like everone else?
  22. #22
    Aug 2005
    Quote Originally Posted by walesy_5.0 View Post
    Yes but an RB30 with RB25/26 head turbocharged and in a VS with a Skyline tranny? Is what I'm proposing THAT common lol?
    Walsy, I'm guessing you've dropped a 5.0Ltr fuel injected in your ride?
    So let's hear it guys, valid arguments between my RB30/36 DET idea to other V8 equivalents.
  23. #23
    walesy's Avatar
    Jun 2005
    Perth SOR
    not ur idea isnt common... i know of like 3 and one of them is in my home town...i agree with airstrike... turbo 5.0...and yeh mines an efi5ltr
  24. #24
    Aug 2005
    Turbo a 5ltr? Sh!T, that would put out some almighty grunt... My Uncle had a supercharged VS ute (5Ltr V8) that used to get wheelspin in 4th gear, so I guess the idea has merit. Only thing is I can't stand the idea of running a car with push-rods, I have this pet hate for push-rods. Still, these RB line of sixes have proven to be real power horses...
  25. #25
    pandaman's Avatar
    pandaman is offline Aussie Muscle Fan
    VN Berlina 5.0 A4
    Feb 2006
    Ahaha, I used to have this irrational hatred of pushrods. But when you think about it what's really wrong with them? Absolutely nothing, as a system it works just fine! There are a few fellas with turbo'd 5L's (and strokers) over on SC. And you're dead right, absolutely silly amounts of power to be had. Plenty of dosh required to do it right though. (As with any big HP motor) All in all it just comes down to personal preference, what do YOU want to do. Not what does everyone else think would be the ****, if you go looking for a consensus opinion on this sort of thing you'll never get anywhere. Just do what's gonna make you happy, because at the end of the day that's what it's gonna be for right?
    Beau Duke: Man, I'm never gonna get outta this car again. I'm gonna live in it, I'm gonna eat in it and I'm gonna make sweet love to it!
    Luke Duke: You mean you're gonna make sweet love IN it.
    Beau Duke: Oh no, I'm gonna have sex with it.
  1. Replies: 47
    Last Post: 30-04-2010, 10:59 PM
  2. It's a hybrid right?
    By kopper69 in forum Jokes/Humour
    Last Post: 17-11-2007, 08:10 PM
  3. vh hybrid
    By brohawk in forum VB - VC - VH - VK
    Last Post: 15-10-2007, 10:32 PM
  4. rb30 Hybrid
    By calaiscairns in forum Straight 6 Development And Modification
    Last Post: 30-05-2006, 07:54 PM
  5. Project Idea really tempting...R31 Skyline running the big 5.0???
    By ruredi in forum V8 Development and Modification
    Last Post: 20-04-2006, 08:52 PM
