Results 1 to 15 of 15
Thread: VL Tacho Dash. different loom to standard?
    HZ Sandman Ute, HZ GTS, VT Senator
    Apr 2006
    Default VL Tacho Dash. different loom to standard?
    is a vl tacho dash wire loom diff to a standard dash loom? or do all vls have the same loom with all the needed wires to plug into the tacho dash if one is fitted?
    cheers
    jason
    It's quicker then your mothers VN
    Sep 2005
    At the time of this post, under your mothers bed with my laptop
    you just plug the dash in the only thing that doesnt work is the oil gauge as exec's dont have the sender
    Apr 2006
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    I have a feeling that the looms are the same but I swapped mine for the one that was in the tacho dash car just to be safe.
    ========My Statesman 20's Mafless and 3.9's========
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    if i recall there are two looms,
    sl and exec loom, clock dash
    berlina and calais loom, tacho
    the reason they are diffrent are because the tacho dash needs the conections for the tacho to the coil or something like that
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Apr 2006
    VL EXEC
    Feb 2007
    Semaphore SA
    ONE set of loom....plug in the one connection plug and the speedo cable...and BAM..u have urself a tacho dash.. done it many of times
    Apr 2006
    Sep 2005
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Just did this mod 5 seconds ago. Took me half an hour tops
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    I put my original speedo into the tacho dash so I could keep my originals K's and also because it was a 5 speed cluster and didn't have the speed sensor on the back of the speedo and it wouldn't kick down without it.
    VT berlina wagon
    Feb 2007
    Actually there are two different patch harnessed for the instrument cluster, depending on if you have clock or tacho dash.
    The easiest way to do the change over is have the correct patch harness which plugs into the main harness (two plugs to the right of the car). I to have done this conversion many times using both methods and using the correct harness means everything works properly and you just need to change the oil sender unit for the guage type and the plug is in the main harness taped up.
    If you dont have the right harness you can fartarse around and have the clock harness adapted to to the job.
    Sabbath''s Avatar
    Jul 2006
    Quote Originally Posted by ucwepn View Post
    I found this problem after i changed my dash out, i believe that the speedo was faulty because it was reading the wrong speed + not clocking over km's. So i pulled it all out again and put my original speedo in there, now shows correct speed, clicks over the km's and what not.
    Oh, and i also forgot to turn my lights off after testing the lighting harness was pushed in correctly, so at 11 when i went out to my car to start it up, wouldnt go...and because of where i park the car, right up against a fence we had to tow the bloody thing out with my girlfriends dads van...major hassles
    VT berlina wagon
    Feb 2007
    There is no difference between the manual and Auto clusters, same partnumber. There were 5 different clusters from factory.
    1. clock dash 6 cyl
    2. Tacho dash 6 cyl
    3. Tacho dash 8 cyl
    4. Calais dash 6 cyl
    5. Calsis dash 8 cyl.
    Difference between V8 and 6 cyl dash is calibration of tacho and speedo, all other gauges in dash the same.
  15. #15
    Sep 2005
    the series 1 calais's were the same as the turbo/berlina's the s2 had the differnt patern and the low fuel light
LinkBacks (?)
  1. 08-12-2011, 11:55 AM
  1. VN Tacho-Less Dash To Tacho
    By Evman in forum General Discussion
    Last Post: 01-03-2008, 08:32 PM
  2. Dash with tacho fit into dash w/out tacho and work????
    By Jamie_87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-11-2007, 09:21 PM
  3. VN Calais dash loom
    By 1redVN in forum Electrical Wiring / Questions
    Last Post: 06-04-2007, 11:13 AM
  4. Replies: 2
    Last Post: 02-11-2005, 07:10 AM
  5. Changing a VP standard dash to a Tacho Dash
    By Madhouse_Dave in forum Electrical Wiring / Questions
    Last Post: 01-07-2005, 11:35 AM
