Results 1 to 3 of 3
Thread: speed sensor
    vl berlina wagon 6cyl
    Jul 2005
    Default speed sensor
    someone mentioned a speed sensor driven from the speedo
    does this mean the car wont run if the speedo stops?
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Well, my car has no dash in it at the moment and starts and goes ok...does that help?
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    If its an auto it will go up through the gears fine without it but will not kick down at all even if you select a lower gear manually. If the speedometer stops working it shouldn't affect the sensor which is driven from the gearbox via cable unless the cable is broken or the gear worn
    ========My Statesman 20's Mafless and 3.9's========
  1. HELP: No Speed sensor, what happens?
    By simc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-10-2005, 10:51 AM
  2. Speed Sensor
    By infernojs in forum Electrical Wiring / Questions
    Last Post: 24-05-2005, 05:37 PM
  3. Speed Sensor
    By infernojs in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-05-2005, 10:35 PM
  4. speed sensor
    By danwalton86VP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-08-2004, 07:41 PM
  5. Speed Sensor
    By vk_calais in forum Electrical Wiring / Questions
    Last Post: 07-03-2004, 09:24 PM
