HELP! my vl high beem lights cut out soon as i put them on high beem, does anyone else have or had this problem? and also my fans only seem to blow air on my feet.. is this a common thing and an easy fix?
lights are prolly due to a relay switch fault as the high beem on my rents vs did the same until i changed a relay and the blowing on ya twinkles is from your vaccumm for ya air vents having a leak or a vaccum hose not being in
Common for the High beam to stuff up.
You will need to get a new stalk for the lights.
cheers guys.. i had a feeling i needed a new stalk
if u check your fuse box u will probably notice your fuse and the surrounding plastics that goes the high beams is melted
every vl ive owned had this problem
wrecking VL COMMODORE 5 speed
FOR SALE : supra 5 speed box suite holden v8 $800
There is a new upgrade to fix that problem, http://niche.iinet.net.au
There's the high end model with fuse blown indication and engine bay timer lights. There is also a barebones one which has no lights and just for
getting the car over the pits, both are DIY type, takes about 30mins...
