Ey guys i got an 86 3.0L Wagon and I wanna know what stuff exactly I need to do a turbo conversion and make it Dose.. and a price.. if you can. Cheers
smockyjnr@gmail.com : MSN
hey just search ebay for a turbo conversion kit complete
Oh dear![]()
^ Indeed.
Just get a friend to hang his head out the window screaming Tu-Tu-Tu-Tu at people as you drive past...full sick uleh.
As for pieces
oil pump
camshaft
pistons & rings
intake plenum
throttle body
plenum coolant hoses
pop off valve
ECU
injectors
AAC valve
fuel pressure reg, control solenoid & surge tank
fuel pump (debateable)
crossover pipe
crossover pipe to turbo heat sheild
air flow meter to turbo ducting metal & plastic piping
detonation sensor & wiring
exhaust manifold
turbocharger
dump pipe & exhaust
oil & water lines for turbocharger
turbocharger heat sheild
charcoal canister
engine fan (earlier models)
ripple red finish in rocker cover
gearbox A/T & M/T
diff
brakes
tacho dash if not berlina or higher
little turbo badge for dash
turbo boot badge
36kw and a bootload of low down torque
as for cost add it up
shouldnt be too bad if you get some bits cheap
this is what i have seen some parts go for as an example
ECU $150
injectors $200
crossover pipe $80
air flow meter to turbo ducting metal & plastic piping $100
detonation sensor & wiring $50 (get from NZ)
exhaust manifold $150
turbocharger $500
dump pipe & exhaust $600 (proper exhaust)
And of course, if you've got an S1 motor forget about it.
But seriously.....you want a car...just so you can dose....![]()
Originally Posted by Reaper:
Originally Posted by Jecs:
go buy a ****box et turbo for 500 bucks ... whack on a cooler and dose all u want if u just want the noise LOL........... but dude save your pennys and go and buy an already turboed vl or a turbo moter..... becasue if u are asking these questions i wouldnt trust u bolting together an n/a convert
but if u must a bare bones n/a conversion kit will cost u around 1300
and would consist of
turbo
turbo lines
x over pipe
injectors
comp
dump pipe
exzaust manifold
and air intake bend that goes to the afm
wrecking VL COMMODORE 5 speed
FOR SALE : supra 5 speed box suite holden v8 $800
yeah i might keep my eye out for a turbo engine.. only reason i want to make it dose is because my wags is canary yellow and it's exactly like the BT1's but in a wagon so i kinda reckon it'd be something different to see a canary yellow wags dose..
........no!
fair call that
nah it just changes
"OmG bR0 DiD u LyK C dAt SiK FuLlI Vl DrOp A Co0La Br0"
to
"OmG bR0 DiD u LyK C dAt FuLlI SiK Vl wAgOn DrOp A Co0La Br0"
by a 900$ complete conversion, get a dose pipe. Then you can dose your wagon all you want.
Until it blows up.
+ a cooler
if your that keen on it,
go and buy a turbo motor, and you dont have to worry bout all the part's and you will no the motor will be strong,
VN Wagon,
wtf does DOSE mean?
i think its got somethng to do with the noise from what ive heard, the zzzzz TU TU TU TU
there one on CT.com genuine needs a new turbo seal, rebuilt for 1g
VN Wagon,
DOSE? what? eh?
{EDIT}
LoL, I should read more, saw it post above mine. Ignore this post...
