Results 1 to 5 of 5
Thread: poor quality fuel vapour hose
    vl berlina wagon 6cyl
    Jul 2005
    Default poor quality fuel vapour hose
    the VL has a complicated fuel vapour collection system from the petrol tank, on the wagon, part of it can be seen by removing the rear inner mudguard plate on the fuel filler side, I expect the sedan is the same
    it all seems to go to a line that I expect goes forward to the carbon cannister
    problem is that holden used cheap clear plastic tubing and this hasnt lasted well, it breaks easily and may well be broken on your VL, allowing petrol fumes to be smelt outside
    VT SS S2 A4
    Aug 2005
    I agree that given the chance, you should replace as much of the plastic/rubber hose as you can.
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Mine disintegrated...i saw a few drops of fluid on the drive, put my hand up to investigate the cause and came back down with fragments of pipe in my hand
    So wheeled the car down the drive (bloody scary cause it was on a hill like \ and then ripped the fuel tank out and all the lines and replaced them.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    Mar 2006
    Quote Originally Posted by harry3 View Post
    Prior to problem and after fixing problem did your fuel tank discharge pressure when you cracked the fuel cap ? Anyone else care to comment ?
    VL
    Jul 2006
    i've had 3 vl's and had to do this on all of them, its a prick of a job too. that stuff they used from the factory was absolute crap
  1. poor quality plastics
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-10-2006, 10:53 PM
  2. 2 VE test vehicles spotted today poor quality pics
    By ucwepn in forum VE Holden Commodore (2006 - ?)
    Last Post: 21-05-2006, 09:09 PM
  3. Poor Quality Plastic Mouldings
    By BobT in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-09-2005, 08:24 AM
  4. VL fuel vapour hoses. Where do they go?
    By Peterb in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-06-2005, 07:07 AM
  5. Fuel tank vapour line setup
    By Radical in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-09-2004, 01:32 PM
