Results 1 to 4 of 4
Thread: fuel tank leaks cure
    vl berlina wagon 6cyl
    Jul 2005
    Default fuel tank leaks cure
    my vl WAGON has had 2 leaks from the fuel tank, from around the inlet to the return line, which was only fixed a whle with epoxy, and now a bad leak apparently from a section of the seam where the 2 halves of the tank are welded tohgether
    since I have an identical parts car in the back yard, I removed both tanks and put the parts one on my wagon, a heck of a job but fairly straightforward
    I finally got to see the swirl pot for the internal fuel pump ( 6 cyl) which can just be seen thru the hole for the internal pump holder, at the right angle
    its brown plastic,oval shape sitting in the bottom and attacked by a rubber hose to inside the return pipe, must have been put there before the 2 hAlves of the tank were joined, gawd only knows what can be done if this pipe eventually rots, the swirl pot is abou1 and a half inches high but there must be some holes in it to allow the last of the fuel in into flow into it
    the idea I suspect is to have plenty of fuel available for the pump when the tank is low
    I swapped the internal pump over, but I couldnt see how or where the pump was sitting down in the fuel bowl
    I had earlier problems due to my new internal pump having a long filter bag all off to one side, this wasnt allowing the pump to sit down low enough in the pot, I turned this 180 degrees and as luck would have it it sits down well, so no more loud fuel gurgling noises or running out of fuel too soon, a short filter bag with half on each side of the bottom of thepump would be better
    no more leaks for now and heres hoping, are VL fuel tank leaks common?
    lessons learned, due to the high pressure, all fuel hose clamps with new hose must be done up very tignt, untill it seems the clamp will break, then tightened again later
    when under the car watch for drops of petrol from hoses that can get into your eyes, ouch!
    the parts car tank had a coating of mud and sand on the bottom, dont know how it got there, I decided to leave it alone, the other tank was surprisingly clean, couldnt see any rust inside either
    both pumps now make different noises, maybe there is still some air in the system
    the grommet around the filler neck isnt yet in properly, but its near enough
    as mentioned, some of the vapor hoses can be inspected by removing the inner back mudguard on the filler side, but if perished, I guess the only problems would be fumes escaping into the air
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Arrow
    Quote Originally Posted by harry3 View Post
    Wagon tanks hold more than sedan tanks too..
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Yeh...it stings like a biatch...and doesnt help when you whack your head on the diff trying to avoid it
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    1987 VL SL
    Nov 2006
    Alice Springs, NT
    I agree with you there. Or when a m8 tries to kill you when your under the car doing the shockies and they sit on the FN thing..... When I got out from underneath the car I beat em' with my air hose..... It was funny afterwards but not at the time. I thought the car was gonna collapse... SCARY
  1. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-09-2010, 04:29 PM
  2. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 08-07-2010, 01:15 PM
  3. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-04-2009, 10:24 PM
  4. Fuel economy per tank of fuel
    By HoZy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-05-2007, 06:58 PM
  5. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-05-2007, 09:01 AM
