Results 1 to 14 of 14
Thread: exhaust system questions
    vl berlina wagon 6cyl
    Jul 2005
    Default exhaust system questions
    re the standard VL 6 cyl exhaust system
    my VL has what looks like the originel exhaust system or must it have been replaced?
    it looks like none of it is stainless steel as a magnet sticks strongly everywhere, looks all like aluminium sprayed steel
    is any of it stainless steel and roughly how long can the exhaust system be expected to last?
    VT SS S2 A4
    Aug 2005
    I would say up to 10 years, depending on where it is driven. ( If you live in an area of high precipitation then that will be reduced and also if you live on the coast )
    I dont think that any of the exhaust would have been stainless steel, mild steel is alot cheaper to use.
    Holden VL Commodore
    Aug 2006
    South Australia, South East
    Depending on what type of steel, can there be any advantage besides look?
    I.e. Stainless stell over normal metal.
    Gavin_LP
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    New exhausts are aluminised. This means that they have a very thin coating of aluminium to stop them going rusty, It's just for looks. An exhaust system can last anywhere from 12 months to 10 years. An aftermarket exhaust will never last as long as the original. The rear muffler is generally the 1st to go, expect that to go around the 2 year mark. The more you drive it the longer it will last. Stainless steel has a 10 year warranty so expect it to last at least that. With stainless systems, you have to make sure all your mounts are in good condition and replace them regularly as any tension on the mufflers will crack them. Stainless tends to be slightly louder than mild steel due to the harmonic characteristics of the metal.
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    most factory stainless systems a magnet will stick too! they are a stainless steel blend last longer and look like stainless! the vl wouldn't have come out with a stainless system.
    Nobody wants to play with me
    Jul 2005
    I think the more the magnet sticks, the poorer the quality of the stainless steel is
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    [QUOTE=harry3;542546]I think the more the magnet sticks, the poorer the quality of the stainless steel is[/QUOTE
    got it in one!
    stainless steel is non-ferrous, ( non-magnetic alloys )
    a real stainless steel exhaust system would cost an absolute fortune = several thousand dollars.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The term stainless steel in exhaust is just a marketing ploy. While they are stainless to a degree they only have just enough nickel content to stop corrosion under ordinary circumstances. They are not 100% stainless, and they will still rust, it just takes longer.
    Holden VL Commodore
    Aug 2006
    What are the laws on the exhaust system, do you have to have a rear muffler? Are high-flow cats' legal?
    I currently have a very dodgy exhaust system and am starting to think I should replace it?
    But I want the flow to be even, not to much back pressure, but not to less.
    Gavin_LP
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Depends on the year of your VL, pre 86 I think you can do what you want as long as it isn't too loud. Post 86 you need the same configuration as factory, but only if you are pulled over and they look at it. 90% of people only have one muffler. Hi flow cats are legal, though unnecessary on a N/A 6 cyl, the standard cat is adequate. Lukey systems on the VL sound good without the rear resonator, part numbers are AL6 4063, and T4059. The tail pipe is the V8 one, still fits though.
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    my exhaust system seems to run fine and its not to big to lose the back presure.
    also has a nice deep rumble at idel and when crusing
    not sure if its over the legal db but have a feeling it could be,
    Extractors,
    high flow cat,
    2.25inch cat back - straight though no rear muffler
    http://youtube.com/watch?v=JQbUXigIVPk
    Gavin if you are in need of a cat back system and aint looking at spending much then Profix marion would be the best place. $200 cat back same as my system fitted. its a cheapy but if you a straped for cash and need one quick also your not botherd if it willl not last as long as a decent brand then its a good option
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Holden VL Commodore
    Aug 2006
    Quote Originally Posted by VL Berlina 5speed View Post
    Thank you for your advice mate , I'm getting extractors soon anyway from the finacial aid of my brother, also a 2.5inch exhaust from the cat back . The exhaust system in Mount Gambier (were I live basically) will cost me around 260. And I don't have a price yet on the extractors.
    Gavin_LP
    Holden VL Commodore
    Aug 2006
    Yes it's been confirmed I'm getting a 2.5 inch from the cat back, (mandrel bent) with only a single muffler.
    Gavin_LP
    It's quicker then your mothers VN
    Sep 2005
    At the time of this post, under your mothers bed with my laptop
    2.5 is to big for an n/a go the 2.25
  1. DIY System Install Questions
    By Radar in forum Car Audio
    Last Post: 22-12-2006, 12:05 PM
  2. cooling system questions
    By SweetWagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-06-2006, 09:24 PM
  3. SLP exhaust system
    By Nospeed in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-09-2005, 08:33 AM
  4. Exhaust system
    By racid3th in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-08-2005, 08:18 PM
  5. New stereo system questions...
    By vl_boy03 in forum Car Audio
    Last Post: 03-06-2004, 12:33 AM
