Results 1 to 8 of 8
Thread: Little Help (spark leads)
    Fr3ak+--'s Avatar
    Fr3ak+-- is offline Closed On Monday
    Vt Exec 5 Speed
    Jul 2006
    Kingswood, Nsw
    Default Little Help (spark leads)
    i replaced my spark plug leads last night and my car is running really bad ever since i did it.. im 85% sure i put them all in the right place but if someone could gimme a quick rundown of which cylinder each lead on the dizzy goes to that would be greatly apreciated
    VT SS S2 A4
    Aug 2005
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    1 5 3 6 2 4 is the firing order. Spin the crank until you get the timing mark to TDC. Loosen number one plug until its just about out, as you spin the crank you should hear a hissing coming from the plug, this will tell you it is the compression stroke. If it doesn't hiss, it's the exhaust stroke and you will have to spin it around once more. When the timing mark is lined up have a look at the rotor button, it will be pointing at number one. This is number one lead, working in a clockwise direction make sure the leads are in the right order on the dizzy.
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Arrow
    Quote Originally Posted by Fr3ak+-- View Post
    You need to find No.1 on the Dizzy and then check that it goes to No.1 spark plug, next is No.5 and so on.
    The firing order is 1-5-3-6-2-4 ANTI-CLOCKWISE..
    Check the pic..
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Oops, I was sure they were clockwise, 5 ltr is clockwise. Oh well, I hope he didn't put them clockwise then.
    Jun 2005
    South OZ Adelaide
    Arrow
    Quote Originally Posted by Not_An_Abba_Fan View Post
    So is Holden 6,
    Hope it's bloody right too
    But there's an direction of rotation arrow on the Dizzy cap also..
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    its quite easy to fix,
    cylinder numbers are counted from front to rear, 1.2.3.4.5.6.
    and with the picture Mag has posted simply run from the corosponding number on the dissy cap to the corosponding cylinder
    also Mag is correct, runs anti clock wise. just pulled out a dissy cap and rotary arm from the cuboard and blow me down its the new one i bought a while ago aswell as my rotary arm.
    just uploading a pic of the cap so you can see its numbers and direction
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
  1. spark leads
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-02-2007, 09:50 PM
  2. Spark plugs and leads
    By GROWLZ in forum General Discussion
    Last Post: 25-06-2006, 04:30 PM
  3. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
  4. Spark Plug Leads
    By Ratty in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-07-2005, 01:49 AM
  5. spark plug leads
    By pcp20us in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-10-2004, 01:30 AM
