Results 1 to 3 of 3
Thread: vl fuel gauge problems
    308commodore's Avatar
    308commodore is offline 308 commodore
    308 VK CALAIS
    Mar 2005
    camira, queensland
    Talking vl fuel gauge problems
    Hey guy's, i've just bought my first vl commodore. It's a vl wagon, 17 inch rims, lowered, monster tacho, tacho dash and reco motor and box (auto). Oh and it's registered. I only paid $500 for it. Bargain hey... It does have one problem though, fuel gauge is playing up. i filled the tank and the gauge read full got home and the next morning it went to full and went to empty as there was no power getting to it? Any ideas? Also the clock on the dash, it works fine but when i put the lights on the clock fades ( which i know it should do ) but then goes bright flickering betwenn dim and normal. Could there be a fault with the instrument cluster or maybe a connection. I would really appreciate any imformation. CHEERS GUY'S...
    Go the allmighty 308 if the bloody thing will run!!!
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    the fuel guage jumping down and say empty when you still have a half tank or so left left is quite common,
    it is caused by the dry solder on the back of the board or the circet braking and not conecting.
    needs to be taken appart and resolderend or bridged with a bit of cable,
    there is a good write up on calaisturbo, ill find the link for you.
    as for the clock could be shorting or a fault in the indercator stalk, electrical fualts are hard to figgerout with out looking at it personally.
    there is two ways posted in that thread, it could bejelpful to you
    http://calaisturbo.com.au/showthread...ght=fuel+gauge
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    vl berlina wagon 6cyl
    Jul 2005
    worth checking the electrical plugs for dirt or corrosion at the petrol tank
  1. Fuel Gauge: Common Problems?
    By Lord-Data in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-09-2009, 11:44 AM
  2. Fuel gauge stuffed? or engine just drinking fuel?
    By Noy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-12-2007, 05:51 PM
  3. gauge problems
    By simba1 in forum Electrical Wiring / Questions
    Last Post: 30-11-2005, 05:49 PM
  4. Problems With the Petrol Gauge
    By timboss04 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-07-2005, 10:56 PM
  5. Holdens answer to VZ Fuel Gauge Problems
    By old mans ute in forum Jokes/Humour
    Last Post: 10-06-2005, 10:50 PM
