Results 1 to 10 of 10
Thread: Pressure in fuel tank
    Mar 2006
    Default Pressure in fuel tank
    Greetings,
    Mar 2006
    Exclamation Tank pressure
    Oops pressed wrong key. Question. Should my VL wagon have pressure in the fuel tank when I crack the cap.If yes then anyone have any previous experience which would explain the absence of pressure in mine.Also has anybody got any specs on fuel pressure to and from tank and info on where to crack lines to test them
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    maybe your breather hose is shot allowing the pressure to escape!
    didn't you say something about a workshop manual?
    any way test your pressure a the high pressure fuel pump under the car and at the inlet hosein the engine bay should read around 250kpa
    p.s. depressurise the fuel system before cracking any hoses! (start the car and remove fuse no. 3 and wait til the engine stops then put the fuse back set up your pressure gauge and test it!)
    Nobody wants to play with me
    vl berlina wagon 6cyl
    Jul 2005
    there shouldnt be any pressure and I dont see how there could be as theres a fume removal system, using about 4 plastic hoses that goes to a charcoal canister
    these hoses often are broken, due to use of poor quality plastic, some of them can be seen by removing the tinware behind the tyre on the filler side, but with hoses broken, it vents to the outside air
    I think the fuel cap shouldnt be vented
    Ive never bothered to use the fuel de pressurisation priocedure, on the advice of a mechanic, I simply wait 5 minutes and all pressure is then gone
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    every mechanic has an opinion! best stick to what the manufacturer recommends hey
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    Quote Originally Posted by harry3 View Post
    pressure should be present!
    take note paragragh B. top right
    Attached Files Attached Files
    Mar 2006
    Thumbs up Tank pressure
    Thanks jatsvl, it is as I thought.I am getting return noises at tank but no pressure.Gunna have to go fishing for faults.Your input will help.Cheers.Yesterday visited skyline r31 site.Lots of good info on many subjects there also.Worthy of a visit by VL fans.
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Exclamation
    Quote Originally Posted by jatsvl View Post
    On mine it looks like the hoses in behind the plate have been replaced already as they are all rubber but 1 has a split in it( the 1 at the very top of the filler neck) tomorrow I'll fix that.
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    Jul 2005
    Jun 2005
    South OZ Adelaide
    Arrow
    interesting, is the copy from the factory workshop manual?
    Looks like a Gregorys..
  1. Fuel tank extreme vapour pressure
    By Helicopter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-01-2011, 07:35 PM
  2. Fuel Pressure Regulator - Poor fuel consumtion
    By Chuckster in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2008, 03:49 PM
  3. Testing in-tank low pressure pump
    By mag in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-11-2007, 02:54 AM
  4. No air pressure for fuel tank
    By Richo2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-01-2006, 02:53 AM
  5. Fuel tank pressure
    By vsv8berlinawag in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2005, 10:39 AM
