Results 1 to 6 of 6
Thread: changing brake booster and cylinder
    vl sl 5spd 6 n/a turbo convert '88
    Apr 2006
    Default changing brake booster and cylinder
    hey guys just got myself a vl turbo diff and 1" master cylinder and turbo brake booster. just wondering how you change the booster and cylinder? can you change it buy the 4 bolts on the back? or do you need to locate where the 2 are behind the dash and change it from there? cheers.
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    2 nuts that go on to the 2 studs that go through the firewall to inside the cabin each side of the pushrod.They are hard to get to so you might need a flexible drive with a universal to get around the steering column and of course you have to remove the spring clip and washer securing the booster pushrod to the pedal arm.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    Apr 2006
    thanks for that and thanks for the quick replys. just finished putting the diff in and adjusted handbrake. so all i got left is to put the booster and master on, bleed the brakes. and when the cars back on the ground fill the diff so i wont overfill it. cheers.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Just remember to pre bleed the master cylinder before you fit it, that way there is less air to bleed out of the rest of the system.
    Apr 2006
    all done and finished. my cars never had such afirm brake pedal in the time i've owned it and thats the third time its had the brakes bled in the time i've owned it (just over a year). thanks for the help guys. cheers.
  1. Vt Master Cylinder And Booster
    By micheledip in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-10-2008, 01:27 AM
  2. master cylinder + booster
    By orbisfactor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-01-2008, 06:36 AM
  3. WTB-vn 5ltr brake booster & master cylinder
    By Calais_5sp in forum Swap / Wanted to Buy / Trade
    Last Post: 20-02-2007, 05:30 PM
  4. Brake booster/cylinder replacement
    By ProMaX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-03-2006, 03:30 PM
  5. Leaking Master Brake Cylinder Connecting to Brake Booster Advice help please.
    By IceDHB in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2005, 02:32 PM
