Results 1 to 8 of 8
Thread: new fuel filter has gone bad
    vl commodore
    Mar 2007
    Australia
    Default new fuel filter has gone bad
    i have put new fuel filter in and car cuts out now but i throttle it and it kicks back in but its pretty bad, blocked fuel line? i dont know
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    you"ll need to pressure test the fuel line. first at the engine 250kpa if not pressure test before the filter!
    I can't see from the info provided that changing your fuel filter would have this affect.
    Nobody wants to play with me
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Unless you put it in backwards. Did it only do this since you changed the filter?
    vl commodore
    Mar 2007
    Australia
    no it did it b4 i put new fuel filter on, but it didnt do it as bas as its doing it nowsumthing gone very wrong yet again, now i wish i can put the stuff back on for gas but i cant now as i have noone to do it
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Is this the same problem you were having? I still think it is your AFM or the connections around it. All the pipes are in good condition, no splits? While it is running, grab the AFM and give it a wiggle and try the plug on the side of it as well.
    1987 VL SL
    Nov 2006
    Alice Springs, NT
    Quote Originally Posted by aussielyn View Post
    Could be your fuel pumps. Turn the car on and listen for a buzzing sound by the back of the car. If its buzzing then your external one is in good order. If its not then its the external one. If you have a full tank of fuel and it still does it then its possibly your internal one. But its usually that the filter was installed sdrawkcab ( backwards )
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Make sure it isn't sucking in any air between the air flow meter and engine. any vaccum leak will upset the AFM and cause similar symptoms
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Also check all your plugs and leads as this is what was wrong with mine and I basically replaced the whole fuel system before I went to a better workshop that diagnosed the real problem.
    ========My Statesman 20's Mafless and 3.9's========
  1. fuel filter
    By R Photon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-04-2006, 09:10 AM
  2. Vt Fuel Filter
    By cuckoo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-11-2005, 09:51 PM
  3. Fuel Filter
    By statey27 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-10-2005, 09:06 AM
  4. Vp fuel Filter
    By mc92ma83 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-12-2004, 07:39 PM
  5. Fuel Filter
    By beno in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2004, 08:46 PM
