Hey fellas just a quick one to tell you all that im putting a turbo in my Commie
Feel free to comment about anything(nice ones)![]()
Basically i want more power out the L
I purchased a $1500 To4E turbo retail(checked make and model on google) for $350 on the trusty Ebay
Turbo Specs:
3 inch inlet
2 inch outlet
Flange- T3/T4 flange (straight bolt-on)
Wheel rating- stage III wheel
Compressor- .60 A/R compressor
Turbine- .63 A/R turbine
Turbine wheel- forged turbine wheel
*turbo is rated upto 600hp
Boost Gauge for $20 and a Turbo Manifold (High mount Mandrel bent SU304 Stainless steel) for $177 Ebay once again.
I Also have a Rising Rate fuel Regulator, and am teeing up a 35mm or 38mm External Wastegate.
Once i got all the bits i go to work. i will update and show pics of the installation, you may be intereseted in.
I have a mate who works for a performance workshop and has inspired me to do this. Im one happy bugger until i accidantly put too much boost in and shoot out a piston through my bonet and kill a low flying duck.
Thanks for lookin'
Nathman
You'll find thats not a $1500 turbo its a cheap chineese copy.
Hopefully it will do ok then ha :P
Thats actually preety scarey.........
it looks and feels preety durable i hope it can handle it
It wont, you really think your going to get a good turbo for $350? i think not
also that manifold probebly would flow any better (maybe even worse?) then a standerd low mount manifold due to the colectors on them
you cant expect big power without spending the money it wont happen
are you just full of insults and critersism dude caus if u are im not interested.
you cant take it anyway you want, good luck with your turbo experience... well all 15 minutes of it
i have an ebay turbo on my vn and it is fine. nothing wrong with it.. i also have a su304 manifold on my ca18det. it went black but does flow a sh_tload better than the stock one.. hopefully your vl one is the same..
sorry. did a double post.
can someone please delete this
ALot of people well tell you that a mate of a mate of a mate had a chinese turbo and it blew up. Show me more than 5 people that have actually had one and destroyed it and I'll be a believer untill then I'll say it's 90% bull****. And I can also show you plenty of people that have blown up Garrett turbos anyway
Everything is made in China these days and the truth it china is getting better everyday, soon they will produce better products than japan.
How many garretts do you hear of blowing up? maybe with 60,000km's of use
yes you can buy good rb26dett runs a master power which i think is a chinese turbo but not so budget look at that turbo it doesnt even have a brand or anything on it
your engine would blo b4 the garret, you'd have pistons poppin out everywhere lol. yeh the whole mate of a mate thing, every1 has a ******** mate who takes his car beyond the point it can handle, its just normal
think about it
cheap turbo $350
cheap turbo rebuild once it blows up $500~
so theres 850 bucks in which you could buy a kkr which are a prity good turbo the only down side is there bush bearing
do it once, do it right
bb is were it is at![]()
Dose Pipe speaks the truth.
Sometimes the truth hurts.
How much PSI do you plan to run at? How much does a standard VLT run at?
Gavin_LP
The brand is XSPOWER
Thanks dan335:P
i can have it all checked out anyways......
ill let you know how it goes.
lol good luck with the xspower turbo![]()
http://ozaudi.com/nuke/modules.php?n...wtopic&p=65062
http://forum.pulsar.org.au/archive/i...p/t-43031.html
http://www.calaisturbo.com.au/archiv...p/t-44244.html
Three seperate forums that all have the same LOW opinion of XS power products.
If you have not bought it, then DO NOT BUY IT!!!
