hey guys. just in the process of buying a decompression plate for when i put my turbo on. and just wondering if anyone know's what the compression will be dropped to with the 1.2mm? and also what it would go to with the 2.0mm? cheers.
Dude more important info is needed but done on some guess work,
the 1.2mm would drop comp to 8.1
the 2.0mm would drop comp to 7.5
Just want to add: no 1 else has answered ur post.
Now I have watch the people answer saying it's wrong-
IF they know the correct anwser why didn't they say??
I was confused now I'm just not so sure!!
RIP Peter (perfect) Brock....
how did you work that out is there a fromula you used?
would be interesting to see how its calculated....
here do u get decompression plates from
1NSANE TOYZ Prezents:
Vl Wagon--GMH 666--![]()
Project at 10% CoMpLeTIoN
100% UnDeRWrApS
the vk sounds like a beast![]()
got it off ebay. asked the bloke i'm getting it off what each one should drop comp to. i'm leaning for the 1.2mm as i was going to leave it standard n/a comp, but after all the things i've been told i thought it would be a good idea to drop it a bit.
if the 1.2mm does drop it to 8.1:1. would that be alright to run around 10 or so psi though the motor without an intercooler? cheers.
Here it is, You ready![]()
16.387 is a number than converts cubic inches to cc's.
Displacement = (Bore ÷ 2)2 x 3.14 x Stroke x 16.387
Head Gasket space = (Bore ÷ 2)2 x 3.14 x Gasket thickness x 16.387064
Deck Height space = (Bore ÷ 2)2 x 3.14 x Deck Height x 16.387064
Compressed Volume = Head Gasket space + Deck Height space +
Piston Top volume + Combustion chamber volume
Uncompressed Volume = Compressed Volume + Displacement
Compression Ratio = Uncompressed volume ÷ Compressed volume
But this is easier http://www.turbofast.com.au/Tfcomp.html
thanks for that mag seems you would need a fair bit of info on an engine first,
hey thanks for that. yeah i've got an intercooler on the way now. just one question. when putting the decomp plate on, which side of it do you put the head gasket? i.e below it (inbetween block and plate) or above it (inbetween plate and head)? thanks for all the info, muc appreciated. cheers.
ok thanks for that. anyone know how long roughly it'll take putting a decomp plate on an rb30? doing it all by hand, no air or electric tools. it'd be the same as doing a headgasket on one really. cheers.
